englet
1
Hello friends!
First of all, YES, I already made my research but no post helped me.
I'm trying for the first time to use the preprocessor directive #if into an Arduino code, but is not working.
Below, a small piece of my code:
#define CARDSIZE 0
// more code...
#if CARDSIZE == 0
int interval = 1000;
#else
int interval = 2500;
#endif
The code always are compiled with interval = 1000, even changing the CARDSIZE value to 1 into its #define...
Can anyone help me?
system
2
byte me;
#define CARDSIZE 8
#if (CARDSIZE == 0)
int StackSize = 1000;
#else
int StackSize = 2500;
#endif
// Serial.print("CARDSIZE: ");
// Serial.println(CARDSIZE);
Serial.print("StackSize: ");
Serial.println(StackSize);
I get StackSize: 2500 when CARDSIZE is set to 8. I get StackSize: 1000 when CARDSIZE is set to 0.
I can only think to blame something that isn't shown in your shortened example. To see that this sort of thing works in general, do something like:
#define CARDSIZE 0
#if CARDSIZE == 0
#error Zero!
#else
#error Nonzero!
#endif
Adjust the value of CARDSIZE to decide how the compile fails.
Riva
4
jaholmes:
There is a difference...
PaulS
#if (CARDSIZE == 0)
jaholmes
#if CARDSIZE == 0
#if (CARDSIZE == 0)
#if CARDSIZE == 0
Both work for me, so does suggest you are resetting 'interval' elsewhere. You could try the alternative #ifdef
#define CARDSIZE0
// more code...
#ifdef CARDSIZE0
#else
#endif
englet
6
Thanks PaulS, your code helped me to find the right way to use the #if. Thanks
