I will send you my code if anyone wants to see it. In my opinion everything is written correctly but the program does not work, it concerns the game Donosaurus on an OLED display 64x128 with SPI. #include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <EEPROM.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, OLED_RESET);
#define BUTTON_PIN 2
#define BUZZER_PIN 3
#define DINO_X 10
#define DINO_HEIGHT 10
#define GROUND_Y 54
#define MAX_OBSTACLES 3
#define MAX_POWERUPS 2
#define MAX_CLOUDS 5
// Dino sprite (10x10)
const uint8_t dinoSprite[] PROGMEM = {
0b00011000,
0b00111100,
0b01111110,
0b11111111,
0b11011011,
0b11111111,
0b01111110,
0b00100100,
0b00100100,
0b00100100
// Bird sprites (5x5)
const uint8_t birdWingUp[] PROGMEM = {
0b00100,
0b01110,
0b11111,
0b01110,
0b00100
const uint8_t birdWingDown[] PROGMEM = {
0b00100,
0b00100,
0b11111,
0b01110,
0b00100
// Zmienne gry
int dinoY = GROUND_Y - DINO_HEIGHT;
bool isJumping = false;
int jumpVelocity = 0;
int gravity = 1;
int obstaclesX[MAX_OBSTACLES];
int obstacleY[MAX_OBSTACLES];
int obstacleType[MAX_OBSTACLES];
int powerUpX[MAX_POWERUPS];
int powerUpY[MAX_POWERUPS];
int powerUpType[MAX_POWERUPS];
bool powerUpActive[MAX_POWERUPS];
bool shieldActive = false;
bool wingState = false;
unsigned long lastWingFlap = 0;
int difficulty = 1;
int obstacleSpeed = 2;
int points = 0;
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(BUZZER_PIN, OUTPUT);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
EEPROM.get(0, difficulty);
if (difficulty < 0 || difficulty > 2) difficulty = 1;
showMenu();
initGame();
void showMenu() {
int selection = difficulty;
bool confirm = false;
unsigned long pressTime = 0;
while (!confirm) {
display.setTextSize(1);
display.setCursor(20, 10);
display.print("Wybierz poziom:");
display.setCursor(20, 25);
display.print(selection == 0 ? "> Latwy" : " Latwy");
display.setCursor(20, 35);
display.print(selection == 1 ? "> Normalny" : " Normalny");
display.setCursor(20, 45);
display.print(selection == 2 ? "> Trudny" : " Trudny");
display.display();
if (digitalRead(BUTTON_PIN) == LOW) {
if (pressTime == 0) pressTime = millis();
if (millis() - pressTime > 800) {
confirm = true;
EEPROM.put(0, selection);
difficulty = selection;
} else if (pressTime != 0) {
pressTime = 0;
selection = (selection + 1) % 3;
delay(200);
obstacleSpeed = 2 + selection;
void initGame() {
for (int i = 0; i < MAX_OBSTACLES; i++) {
obstaclesX[i] = 128 + i * 40;
obstacleY[i] = GROUND_Y - 8;
obstacleType[i] = random(0, 2);
for (int i = 0; i < MAX_POWERUPS; i++) {
powerUpX[i] = 128 + i * 60;
powerUpY[i] = random(20, GROUND_Y);
powerUpType[i] = random(0, 3);
powerUpActive[i] = true;
unsigned long now = millis();
if (now - lastWingFlap > 200) {
wingState = !wingState;
lastWingFlap = now;
if (digitalRead(BUTTON_PIN) == LOW && !isJumping) {
isJumping = true;
jumpVelocity = -8;
tone(BUZZER_PIN, 800, 100);
// Skakanie
if (isJumping) {
dinoY += jumpVelocity;
jumpVelocity += gravity;
if (dinoY >= GROUND_Y - DINO_HEIGHT) {
isJumping = false;
// Przeszkody
obstaclesX[i] -= obstacleSpeed;
if (obstaclesX[i] < -10) {
obstaclesX[i] = 128 + random(30, 80);
// Kolizje
if (obstaclesX[i] < DINO_X + 10 && obstaclesX[i] + 8 > DINO_X &&
dinoY + DINO_HEIGHT > obstacleY[i]) {
if (shieldActive) {
gameOver();
// Power-upy
if (powerUpActive[i]) {
powerUpX[i] -= obstacleSpeed;
if (powerUpX[i] < -5) {
powerUpX[i] = 128 + random(50, 100);
powerUpY[i] = random(20, GROUND_Y - 5);
// Zbieranie
if (powerUpX[i] < DINO_X + 10 && powerUpX[i] + 5 > DINO_X &&
dinoY + 10 > powerUpY[i] && dinoY < powerUpY[i] + 5) {
switch (powerUpType[i]) {
case 0: shieldActive = true; break;
case 1: points += 500; break;
case 2: obstacleSpeed = max(1, obstacleSpeed - 1); break;
powerUpActive[i] = false;
tone(BUZZER_PIN, 1000, 150);
// Rysowanie
display.drawLine(0, GROUND_Y, SCREEN_WIDTH, GROUND_Y, SSD1306_WHITE);
// Dino
display.drawBitmap(DINO_X, dinoY, dinoSprite, 8, 10, SSD1306_WHITE);
// Przeszkody
if (obstacleType[i] == 0) {
display.fillRect(obstaclesX[i], obstacleY[i], 8, 8, SSD1306_WHITE); // kaktus
display.drawBitmap(obstaclesX[i], obstacleY[i],
wingState ? birdWingUp : birdWingDown, 5, 5, SSD1306_WHITE);
// Power-upy
display.fillCircle(powerUpX[i], powerUpY[i], 2, SSD1306_WHITE);
// Punkty
points++;
display.setCursor(90, 0);
display.setTextColor(SSD1306_WHITE);
display.print("PTS:");
display.print(points);
// Ikonka tarczy
if (shieldActive) {
display.drawCircle(DINO_X + 4, dinoY + 5, 8, SSD1306_WHITE);
display.display();
delay(30);
void gameOver() {
display.setTextSize(2);
display.setCursor(10, 20);
display.print("Game Over");
display.print("Punkty: ");
display.display();
tone(BUZZER_PIN, 300, 500);
noTone(BUZZER_PIN);
while (digitalRead(BUTTON_PIN) == HIGH); // Czekaj na przycisk
while (digitalRead(BUTTON_PIN) == LOW); // Zwolnienie
// Restart
points = 0;
initGame();
Thank you
