I am trying to make a project which the piezo buzzer is controlled by the photo resistor. while it does not work with 9v battery or connected with my laptop until the laptop is charging.
Does it mean that the voltage is not enough? while I dont know why it happens, since I feel like the buzzer and photo resistor I use in this project dont require really high voltage?
did you soldered the wires directly to the Arduino.? If "YES" Please re-check connections, if "NO" or using the barrel jack pin, check the battery voltage, look for it's charge.
Try changing the USB port, maybe that port is internally damaged.??
@Anrn, post the program you have uploaded to your Arduino and also make a simple pencil drawing showing how YOU have everything connected and post a photo of the drawing.
Robin2: @Anrn, post the program you have uploaded to your Arduino and also make a simple pencil drawing showing how YOU have everything connected and post a photo of the drawing.
Thank you
Hi, I didn't solder the wires directly to the arduino. and I tried other 9v battery using barrel jack pin and change the usb port, still doesnt work.
