Why can't I use the copied/pasted libraries such as SdFat or others as per the picture here:
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
Ethernet is in yellow colour and works fine but SdFat or SdFatUtil stay in black, seems not recognized by the program. All new libraries are not recognized... why ? How can I fix this problem on Arduino 1.0.5 on Windows 7 unfortunately?
dpasquazzo:
#include <SdFat.h>
Perhaps you are not downloading them and storing them in the proper directory? Added libraries need to be downloaded/extracted and stored in a directory that you create in your user sketch directory and name the new directory libraries. Inside that library directory will be folders named the same as the .cpp and .h files stored in them.
Example in my windows system:
C:\Documents and Settings\Primary Windows User\My Documents\Arduino\Arduino1\libraries\SdFat
contains the files SdFat.h and SdFat.cpp along with support and example files that the library uses.
Lefty
I can successfully import libraries FAT or SdFat but both seems not working (library name in the code remains in black color). Other imported Libraries such as Ethernet.h or DallasTemperature.h seems working fine (code change library name to yellow color)
dpasquazzo:
Well the text changing colors depends on if the specific library includes a keywords.txt file created for that specific library.
Lefty
