Why on eart dont this work - 2 x buttons ?
Hi, today my hair is going grey.
I really dont understand why this code dont work, nothing on serial when pressing buttons
buttons is connected between GND and GPIO.
I run this on an ESP32 OLED LiLigo
const int nextPin = 34;     // les next kube data, knapp til høyre
const int previousPin = 35;   // les previous kube data, knapp til venstre
int previousButtonState;                 // the current reading from the input pin
int lastpreviousButtonState = HIGH;       // the previous reading from the input pin
unsigned long lastpreviousDebounceTime = 0;  // the last time the output pin was toggled
int nextButtonState;                   // the current reading from the input pin
int lastnextButtonState = HIGH;         // the previous reading from the input pin
unsigned long lastnextDebounceTime = 0;    // the last time the output pin was toggled
unsigned long debounceDelay = 50;       // the debounce time; increase if the output flickers
  pinMode(previousPin, INPUT_PULLUP);
  pinMode(nextPin, INPUT_PULLUP);
  Serial.begin(115200);                 // Start seriell kommunikasjon for debugging
  // read the state of the switches into local variables:
  int previousReading = digitalRead(previousPin);
  int nextReading = digitalRead(nextPin);
  // Debounce previousPin
  if (previousReading != lastpreviousButtonState) {
    lastpreviousDebounceTime = millis();
  if ((millis() - lastpreviousDebounceTime) > debounceDelay) {
    if (previousReading != previousButtonState) {
      previousButtonState = previousReading;
      if (previousButtonState == LOW) {
        Serial.println("Previous button");
  lastpreviousButtonState = previousReading;
  // Debounce nextPin
  if (nextReading != lastnextButtonState) {
    lastnextDebounceTime = millis();
  if ((millis() - lastnextDebounceTime) > debounceDelay) {
    if (nextReading != nextButtonState) {
      nextButtonState = nextReading;
      if (nextButtonState == LOW) {
        Serial.println("Next button");
  lastnextButtonState = nextReading;
Do pins 34 and 35 support INPUT_PULLUP ?
You should read this to prevent loosing hair
>No....
Thanks
I have changed pins and now it works.
Thanks, I will store the Random link for next time, to prevent hair loss :wink:
@UKHeliBob gave ma a good tip.
I have studied quite a bit GPIOs for ESP WROOM, youtube -> Spiess.
For this OLED ESP there is SD card enabled, LoRa enabled and OLED enabled that gives an extra challenge for me.
