Hi
Ive got the code working now. But i still dont understand why some functions are coloured orange like forward and reverse, whereas spin stays black.
int motor1pin = 3 ; // H bridge pin 2
int motor2pin = 4 ; // H bridge pin 7
int motor3pin = 6 ; // H bridge pin 10
int motor4pin = 7 ; // H bridge pin 15
int motor1speed = 9 ; // To En pin 1: Use PWM to alter speed of motor 1
int motor2speed = 2 ; // To En pin 9: Use PWM to alter speed of motor 2
int led = 13;
int dist;
int vel;
void setup ()
pinMode (motor1speed, OUTPUT); // Define pins as outputs
pinMode (motor2speed, OUTPUT);
pinMode (motor1pin, OUTPUT );
pinMode (motor2pin, OUTPUT );
pinMode (motor3pin, OUTPUT );
pinMode (motor4pin, OUTPUT );
pinMode (led,OUTPUT);
void stop ()
digitalWrite (motor1speed, LOW); // Make pin 1 (En) low to stop motor 1
digitalWrite (motor2speed, LOW); // Make pin 9 (En) low to stop motor 2
void forward (int dist, int vel) // Forward function, dist is time in milliseconds, vel is speed
digitalWrite(led,HIGH); // just for debugging
digitalWrite(motor1pin, LOW); // Set H bridge pins to move both motors in the same direction
digitalWrite(motor2pin, HIGH);
digitalWrite(motor3pin, LOW);
digitalWrite(motor4pin, HIGH);
analogWrite (motor1speed, vel); // Turn on motor 1 by supplying a value 0-255 to En (pin 1)
analogWrite (motor2speed, vel); // Turn on motor 2 by supplying a value 0-255 50 En (pin 9)
delay (dist); // keep both motors going for dist milliseconds
void reverse (int dist, int vel) // Reverse function, just reverse HIGH and LOW commands
digitalWrite(led,LOW); // just for debugging
digitalWrite(motor1pin, HIGH);
digitalWrite(motor2pin, LOW);
digitalWrite(motor3pin, HIGH);
digitalWrite(motor4pin, LOW);
delay (dist);
void spin (int dist, int vel)
delay (dist);
forward (5000,170); // forward for 5 seconds at about half speed
stop (); // stop both motors
delay (2000); // wait 2 seconds
reverse (5000,170); // reverse
stop();
delay(2000);
spin (1000,200); // spin alter parameters to go 180 degrees
stop ();
delay (2000);
