In this example:
It suggests using pin 4 for the SPI chip select.
But the hardware chip select pin for the SPI header is pin 16/A2 on the Zero.
Perhaps this doesn't matter; but if it doesn't, I'm not sure why there's a hardware pin at all, and this page states that even if you use another pin, the hardware pin must be left set as output:
Of course this info might be out of date and only apply to Atmega chips; I'm not sure. But if it is accurate then the logical thing to do would be to specify pin 16 be used in the tutorial.
