Why pin49 isn't turning off in my code?
pin 49 is never turning off. it doesn’t turn off when I press the button to activate ‘square16solid’ function, and it never turns off during ‘square16’ function.
I pasted the main parts to my code since it was over the 9500 limit. Thanks!
#define DEBOUNCE 10
// output pins
int inMin = 2;
int inMax = 49;
//input pins
byte button[16]= {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15};
#define NUMBUTTONS sizeof(button)
byte buttonpressed[NUMBUTTONS], pressed[NUMBUTTONS];
boolean state[16];
boolean lastState[48];
boolean oldState[16];
long previousMillis[48];
long interval[48] = {500, 600, 550, 500, 600, 550, 500, 600, 550, 500, 600, 550, 500, 600, 550, 500, 600, 550, 500, 600, 550,
                  500, 600, 550, 500, 600, 550};
long time[48];
  byte i;
  for(int i=inMin; i<inMax; i++)
   pinMode(i, OUTPUT);
for(int i=0; i<15; i++)
   buttonpressed[i] = 0;
   state[i] = LOW;
   pinMode(button[i], INPUT);
   oldState[i] = LOW;
for(int i=0; i<47; i++)
   previousMillis[i] = 0;
   time[i] = millis();
   lastState[i] = LOW;
void check_switches() {
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  if (millis() < lasttime){
    lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) {
    return;
for (index = 0; index < NUMBUTTONS; index++) {
buttonpressed[index] = 0;
currentstate[index] = digitalRead(button[index]);
if(currentstate[index] == previousstate[index]) {
  if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
    buttonpressed[index] = 1;
  pressed[index] = !currentstate[index];
previousstate[index] = currentstate[index];
  check_switches();
 ////////////Square 1/////////////////
     if (oldState[0] != buttonpressed[0])  // check for state change
    if(buttonpressed[0]) // if button state is HIGH, then do something
      state[0]++;
      if (state[0] > 1)
        state[0] = 0;
    oldState[0] = buttonpressed[0]; // update lastState
  if (state[0] == 0)
    square1();
  else if (state[0] == 1)
    square1solid();
    ////////////Square 16/////////////////
     if (oldState[15] != buttonpressed[15])  // check for state change
    if(buttonpressed[15]) // if button state is HIGH, then do something
      state[15]++;
      if (state[15] > 1)
        state[15] = 0;
    oldState[15] = buttonpressed[15]; // update lastState
  if (state[15] == 0)
    square16();
  else if (state[15] == 1)
    square16solid();
/////////////////////////////////Square 1///////////////////////////////////
void square1solid() {
  digitalWrite(2, HIGH);
  digitalWrite(3, LOW);
  digitalWrite(4, LOW);}
void square1(){
  unsigned long currentMillis1 = millis();
   if (currentMillis1 - time[0] > interval[0]) {
     time[0] = currentMillis1;
        if(lastState[0] == LOW)
          lastState[0] = HIGH;
          lastState[0] = LOW;
          digitalWrite(2, lastState[0]);
  unsigned long currentMillis2 = millis();
   if (currentMillis2 - time[1] > interval[1]) {
     time[1] = currentMillis2;
        if(lastState[1] == LOW)
          lastState[1] = HIGH;
          lastState[1] = LOW;
          digitalWrite(3, lastState[1]);
     unsigned long currentMillis3 = millis();
   if (currentMillis3 - time[2] > interval[2]) {
     time[2] = currentMillis3;
        if(lastState[2] == LOW)
          lastState[2] = HIGH;
          lastState[2] = LOW;
          digitalWrite(4, lastState[2]);
         /////////////////////////Square 16////////////////////////////////
void square16solid() {
  digitalWrite(47, HIGH);
  digitalWrite(48, LOW);
  digitalWrite(49, LOW);}
void square16(){
 unsigned long currentMillis46 = millis();
   if (currentMillis46 - time[45] > interval[45]) {
     time[45] = currentMillis46;
        if(lastState[45] == LOW)
          lastState[45] = HIGH;
          lastState[45] = LOW;
          digitalWrite(47, lastState[45]);
  unsigned long currentMillis47 = millis();
   if (currentMillis47 - time[46] > interval[46]) {
     time[46] = currentMillis47;
        if(lastState[46] == LOW)
          lastState[46] = HIGH;
          lastState[46] = LOW;
          digitalWrite(48, lastState[46]);
     unsigned long currentMillis48 = millis();
   if (currentMillis48 - time[47] > interval[47]) {
     time[47] = currentMillis48;
        if(lastState[47] == LOW)
          lastState[47] = HIGH;
          lastState[47] = LOW;
          digitalWrite(49, lastState[47]);
Mattdryer:
Did you set that pin to output?
   pinMode(i, OUTPUT);
int inMax = 49;
i
Yeah i thought the way I wrote it was okay.
With inmax at 49, wouldn't it get to 48, it will be less than 49 so it will add one to get to 49? Or is it supposed to be 50?
Or:
for(int i=inMin; i <= inMax; i++)
Matt, the loop tests the condition and then operates the index… that’s why it doesn’t get to 10 here.
So in the following example the loop runs ten times.
the i variable is set to 0.
a condition is created for the loop to run if the “i < 10” test is successful.
the counter i is increased by 1 each time the loop runs
  for(int i = 0; i < 10 ; i++)
    Serial.println(i);
outputs this:
0
1
2
3
4
5
6
7
8
9
this syntax by the way makes it particularly nice for arrays, for example:
int myArray[10];
where the first element is zero, not one. It is easy to match the array size(10) to the for loop syntax
BullDog, thanks a lot for your help. I never had anyone explain it to me that way, makes complete sense (and would explain a lot of other past code issues I've had haha). I'm clearly a noob but I love learning this stuff.
You've helped me a lot with this project and I've learned a ton, thank you!!
