Why string in "" work but String variable doesn't (IniFile library function)
Why this example work:
#include <IniFile.h>
  const size_t bufferLen = 80;
  char buffer[bufferLen];
  IniFile ini("nazwapliku");
  ini.getValue("network", "mac", buffer, bufferLen);
and this doesn't work:
  String fName = "nazwapliku";
  IniFile ini(fName);
and this one doesn't, how to use here variable instead of string in ""?
When I try to compile second one then I got error message:
Compiling debug version of 'IniFileExample' for 'Arduino/Genuino Uno'
IniFileExample.ino: In function void setup()
Error compiling project sources
Debug build failed for project 'IniFileExample'
IniFileExample.ino: 10:18: error: no matching function for call to 'IniFile::IniFile(String&)
   IniFile ini(fName)
IniFileExample.ino:10: note  candidates are
IniFileExample.ino: In file included from
IniFile.h:30: note  IniFile  IniFile(const char*, uint8_t, bool)
   IniFile(const char* filename, uint8_t mode = FILE_READ
IniFile.h:30: note    no known conversion for argument 1 from String to const char*
IniFile.h:13: note  constexpr IniFile  IniFile(const IniFile&)
   class IniFile {
IniFile.h:13: note    no known conversion for argument 1 from String to const IniFile&
If this can help in any way than I use this library -> GitHub - stevemarple/IniFile: Arduino library to parse ini files.
Use
  char fName[] = "nazwapliku";
and unless you have a 32 Bit Arduino or an ESP8266 forget about Strings altogether.
The function takes a character pointer, not a String object. You can store your value as a character pointer:
  char *fName = "nazwapliku";
  IniFile ini(fName);
or as a character array:
  IniFile ini(fName);
or put it in a character buffer (array):
  char fName[20];
  strncpy(fname, "nazwapliku", 20);
  IniFile ini(fName);
thanks :slight_smile:
