This is a example code from:
https://bitbucket.org/teckel12/arduino-new-ping/wiki/Home
The #define ITERATIONS 5 // Number of iterations.
but the Serial monitor file loops upto 27 times, why?
Thanks
Adam
#include <NewPing.h>
#define TRIGGER_PIN 4 // Arduino pin tied to trigger pin on ping sensor.
#define ECHO_PIN 5 // Arduino pin tied to echo pin on ping sensor.
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
#define PING_INTERVAL 33 // Milliseconds between sensor pings (29ms is about the min to avoid cross-sensor echo).
unsigned long pingTimer[ITERATIONS]; // Holds the times when the next ping should happen for each iteration.
unsigned int cm[ITERATIONS]; // Where the ping distances are stored.
uint8_t currentIteration = 0; // Keeps track of iteration step.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
pingTimer[0] = millis() + 75; // First ping starts at 75ms, gives time for the Arduino to chill before starting.
for (uint8_t i = 1; i < ITERATIONS; i++) // Set the starting time for each iteration.
pingTimer[i] = pingTimer[i - 1] + PING_INTERVAL;
for (uint8_t i = 0; i < ITERATIONS; i++) { // Loop through all the iterations.
if (millis() >= pingTimer[i]) { // Is it this iteration's time to ping?
pingTimer[i] += PING_INTERVAL * ITERATIONS; // Set next time this sensor will be pinged.
if (i == 0 && currentIteration == ITERATIONS - 1) oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
sonar.timer_stop(); // Make sure previous timer is canceled before starting a new ping (insurance).
currentIteration = i; // Sensor being accessed.
cm[currentIteration] = 0; // Make distance zero in case there's no ping echo for this iteration.
sonar.ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
Serial.print("pingTimer");
Serial.print(i);
Serial.print("=");
Serial.println(pingTimer[i]);
Serial.print("cm");
Serial.print(i);
Serial.print("=");
Serial.println(cm[currentIteration]);
// Other code that *DOESN'T* analyze ping results can go here.
void echoCheck() { // If ping received, set the sensor distance to array.
if (sonar.check_timer())
cm[currentIteration] = sonar.ping_result / US_ROUNDTRIP_CM;
Serial.print("cm60=");
void oneSensorCycle() { // All iterations complete, calculate the median.
unsigned int uS[ITERATIONS];
uint8_t j, it = ITERATIONS;
uS[0] = NO_ECHO;
for (uint8_t i = 0; i < it; i++) { // Loop through iteration results.
if (cm[i] != NO_ECHO) { // Ping in range, include as part of median.
if (i > 0) { // Don't start sort till second ping.
for (j = i; j > 0 && uS[j - 1] < cm[i]; j--) // Insertion sort loop.
uS[j] = uS[j - 1]; // Shift ping array to correct position for sort insertion.
} else j = 0; // First ping is sort starting point.
uS[j] = cm[i]; // Add last ping to array in sorted position.
} else it--; // Ping out of range, skip and don't include as part of median.
Serial.print("cm78=");
Serial.print(uS[it >> 1]);
Serial.println("cm");
delay(2);
SERIAL MONITOR FILE:
cm1=0
cm2=0
cm3=0
cm4=0 ///////////////////// 1
cm0=0
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 2
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 3
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 4
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 5
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 6
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 7
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 8
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 9
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 10
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 11
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 12
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 13
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 14
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 15
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 16
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 17
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 18
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 19
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 20
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 21
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 22
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 23
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 24
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 25
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 26
cm1=0
cm2=0
cm3=0
cm4=0
cm0=0 ///////////////////// 27
cm1=0
cm2=0
cm3=0
cm4=0
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer0=240
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer1=273
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer2=306
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer3=339
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer4=372
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm78=
26cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=15
pingTimer0=405
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm60=0
cm60=0
cm60=0
cm60=27
pingTimer1=438
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm60=0
cm60=0
cm60=0
cm60=27
pingTimer2=471
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer3=504
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer4=537
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm78=
15cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=15
pingTimer0=570
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer1=603
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm60=0
cm60=0
cm60=0
cm60=27
pingTimer2=636
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer3=669
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm60=0
cm60=0
cm60=0
cm60=27
pingTimer4=702
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm78=
15cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=15
pingTimer0=735
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm60=0
cm60=0
cm60=0
cm60=27
pingTimer1=768
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer2=801
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer3=834
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer4=867
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm78=
26cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=33
pingTimer0=900
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm1=33
cm2=33
cm3=33
cm4=33
cm0=33
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer1=933
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer2=966
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer3=999
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm60=0
cm60=0
cm60=0
cm60=27
pingTimer4=1032
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm0=27
cm1=27
cm2=27
cm3=27
cm4=27
cm78=
26cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=15
pingTimer0=1065
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer1=1098
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer2=1131
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer3=1164
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer4=1197
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm78=
8cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=15
pingTimer0=1230
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm1=15
cm2=15
cm3=15
cm4=15
cm0=15
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer1=1263
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer2=1296
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm60=0
cm60=0
cm60=0
cm60=8
pingTimer3=1329
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm4=8
cm0=8
cm1=8
cm2=8
cm3=8
cm60=0
cm60=0
cm60=0
cm60=26
pingTimer4=1362
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm0=26
cm1=26
cm2=26
cm3=26
cm4=26
cm78=
15cm
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=0
cm60=33
