Why the signal strength is empty?
I'v a GSM shield and Arduino Uno. I am able to get the following message from Serial Monitor using example programme: GSM/Tools/gsmNetworkScan.
GSM networks scanner looping start looping end Modem IMEI: 359231038101091 Scanning available networks. May take some seconds.
STARHUB Pte Ltd MOBILEONE SingTel
Current carrier: Signal Strength: [0-31] Scanning available networks. May take some seconds.
Thanks for any help...
same here. Did you solve the problem?
Best regards
Execute the sketch replacing the line:
GSM gsmAccess;
with:
GSM gsmAccess(true);
Post your serial output.
Replacing GSM gsmAccess; with: GSM gsmAccess(true); doesn't change the serial output. I partially solved the problem commenting this lines:
// Serial.println("Scanning available networks. May take some seconds."); // Serial.println(scannerNetworks.readNetworks());
now "current carrier" and "signal strength" are working.
I don't understand. In my shield in Spain works perfectly. Although, it's possible there may be a bug in the library. Could you show more details?.
i have a similar problem, but i didnt find a solution for me. if i upload program from my old notebook (Dell Vostro, win7 sp1) everything works good. Bud if i upload the same scatch from any other computer, signalStr is 0. Please, can someone help me?
Code:
#include <GSM.h>
#define PINNUMBER “”
#define GPRS_APN “Internet”
#define GPRS_LOGIN “”
#define GPRS_PASSWORD “”
GSMClient client;
GPRS gprs;
GSMScanner signalScanner;
GSMModem modem;
boolean unconnected = true;
boolean serverConnected = false;
String IMEI = “”;
while (unconected) {
if (gsmAccess.begin(PINNUMBER) == GSM_READY){
Serial.println(“GSM ready”);
if (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY) {
unconnected = false;
Serial.println("!!! ERROR !!!");
delay(200);
Serial.println(“GPRS ready”);
String net;
int signalStr;
net = signalScanner.getSignalStrength();
// Serial.println(“Scanning available networks. May take some seconds.”);
signalStr = net.toInt() * (100 / 31);
Serial.print(“signal strength: “);
Serial.print(SignalStr);
Serial.println(” %”);
delay(2000);
