I've seen this code on the internet and its really working but when i try to integrate it to node-red using mqtt protocol the sigMin value is always at 0.
#define BROKER_IP "192.168.254.110"
#define DEV_NAME "mqttdevice"
#define MQTT_USER "mqtt_user"
#define MQTT_PW "mqtt_password"
#include <WiFiNINA.h>
#include <MQTT.h>
const char ssid[] = "HG8145DV5_3DD8F0E";
const char pass[] = "rSCvgF9E2GE";
const char topic[] = "motor";
WiFiClient net;
MQTTClient client;
const int sensitivity = -58;
const int gain = 20;
const int sensorPIN = A0;
const int sampleWindow = 1000;
unsigned int sample;
void connect() {
Serial.print("checking wifi...");
Serial.print(".");
Serial.print("\nconnecting...");
while (!client.connect(DEV_NAME, MQTT_USER, MQTT_PW)) {
Serial.print(".");
Serial.println("\nconnected!");
client.subscribe("\mqtt_table_1"); //SUBSCRIBE TO TOPIC /hello
void messageReceived(String &topic, String &payload) {
Serial.println("incoming: " + topic + " - " + payload);
WiFi.begin(ssid, pass);
client.begin(BROKER_IP, 1883, net);
client.onMessage(messageReceived);
connect();
if (!client.connected()) {
connect();
client.loop();
unsigned long startMillis= millis();
unsigned int peakToPeak = 0;
unsigned int signalMax = 0;
unsigned int signalMin = 1024;
// collect data for Sample window width in mS
while (millis() - startMillis < sampleWindow)
sample = analogRead(sensorPIN);
if (sample < 1024)
if (sample > signalMax)
signalMax = sample;
else if (sample < signalMin)
signalMin = sample;
peakToPeak = signalMax - signalMin;
double volts = ((peakToPeak * 5.0) / 1024)*10;
double volts_db = 20*log10(volts/0.001259);
double spl_db = volts_db + 94 + sensitivity - gain;
String dB_mqtt = String(spl_db, 2);
client.publish("mqtt_table_1", dB_mqtt);
Serial.print("sample: " + String(sample) );
Serial.print("\t");
Serial.print("signalMax: " + String(signalMax) );
Serial.print("\t");
Serial.print("signalMin: " + String(signalMin) );
Serial.print("\t");
Serial.print("peakToPeak: " + String(peakToPeak) );
Serial.print("\t");
Serial.print("volts: " + String(volts) );
Serial.print("\t"); // prints a tab
Serial.print("dB: " + String(volts_db) );
Serial.print("\t");
Serial.println("dB-spl: " + String(spl_db) );
Here is the output
14:07:48.064 -> sample: 667 signalMax: 1018 signalMin: 0 peakToPeak: 1018 volts: 49.71 dB: 91.93 dB-spl: 107.93
14:07:49.051 -> sample: 579 signalMax: 1019 signalMin: 0 peakToPeak: 1019 volts: 49.76 dB: 91.94 dB-spl: 107.94
14:07:50.083 -> sample: 476 signalMax: 1018 signalMin: 0 peakToPeak: 1018 volts: 49.71 dB: 91.93 dB-spl: 107.93
14:07:51.144 -> sample: 452 signalMax: 1018 signalMin: 0 peakToPeak: 1018 volts: 49.71 dB: 91.93 dB-spl: 107.93
14:07:52.176 -> sample: 481 signalMax: 1018 signalMin: 0 peakToPeak: 1018 volts: 49.71 dB: 91.93 dB-spl: 107.93
I wonder why it always stays at maximum value
