Why this code definition LCD this way?
One code has a way to definite LCD like:
//LCD Output
 #ifdef LCD_PRINT
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);           //RS,E,D4,D5,D6,D7
 #endif
any specialities and advantages?
Thanks
Adam
Compared to what?
What other way(s) have you seen it definited?
a7
HI @shanren
For this library (<LiquidCrystal.h>) this is the default format.
RV mineirin
class LiquidCrystal : public Print {
public:
  LiquidCrystal(uint8_t rs, uint8_t enable,
		uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3,
		uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7);
  LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
		uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3);
Thanks.
I used to do this way, and that works.
/////  const int rs = 8, en = 9, d4 = 10, d5 = 11, d6 = 12, d7 = 13;
const int rs = 7, en = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
Explain better.
Thanks.
Attached a code below, that doesn't make my LCD work. if comment out all #ifdef LCD_PRINT and #endif , my LCD works.
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//LCD Output
 #ifdef LCD_PRINT
 #endif
   #ifdef LCD_PRINT
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("ADAMDIY-ADMM");
  lcd.clear();
  lcd.setCursor(0, 1);
  lcd.print("hello, world!");
  #endif
Go learn about
# define
# ifdef
    and
# endif
You don’t
# define LCD_PRINT
anywhere, so you code gets skipped. Not included.
a7
Hi @shanren
There is no definition of LCD_PRINT
try this sketch:
#define LCD_PRINT
//LCD Output
#ifdef LCD_PRINT
//const int rs = 7, en = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
#endif
#ifdef LCD_PRINT
  lcd.begin(16, 2);
  lcd.clear();
  lcd.clear();
#endif
Thanks.
Thanks.
The sketch works well.
Is this mean every time if I like to display some thing, I always need use this pattern?
#ifdef LCD_PRINT
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print("xxxx");
  lcd.clear();
  lcd.print("yyyy");
#endif
and how about the post #3, that just need one time right?
Thanks.
In post #3 I just showed how it is written inside the library "LiquidCrystal".
RV mineirin
Thank you.
