why this code gives error message ?
#include <stdio.h>
#define GRAYSCALE
void set_pixel_data(int depth, void *p);
struct pixel_gray { char m; };
struct pixel_color { char r; char g; char b; };
int main()
struct pixel_gray pg;
struct pixel_color pc;
#ifdef GRAYSCALE
set_pixel_data( 1, &pg);
#else
set_pixel_data( 3, &pc);
#endif
return(0);
void set_pixel_data(int depth, void p)
struct pixel_gray p1;
switch(depth)
case 1:
p1=(struct pixel_gray
)p; //here is issue why??
case 3:
printf("33");
default:
printf("nothing he he ");
what is the error?
p1=(struct pixel_gray*)p; //here is issue why??p1 is not a pointer.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
wounder1:
case 1:
That should be:
case 1:
p1 = *(struct pixel_gray*)p;
johnwasser:
That should be:
case 1:
p1 = (struct pixel_gray)p;
He shouldn't be casting things to void* in the first place.
Pieter
