I don't get it, even if I "hide" the rest of the code inside the loop, it continues to have a delay... The code is still a "bit" messy:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <Time.h>
#include <Timezone.h> //https://github.com/JChristensen/Timezone
#include <DS1307RTC.h>
//COLOR DEFINITIONS
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFE0
#define WHITE 0xFFFF
#define GREY 0x8410
// ARRAY TO REPLACE SINGLE DIGITS WITH LEADING ZEROES
char* leadingZero[] = {
"00", "01", "02", "03", "04", "05", "06", "07", "08", "09"
//////VARIABLES TO HOLD COLOR VALUES///////////
int redValue = 0;
int grnValue = 0;
int bluValue = 0;
////////////////TFT SHIELD STUFF///////////////
//Use these pins for the shield!
#define sclk 52//13
#define mosi 50//11
#define miso 51 //not need
#define cs 10
#define dc 8
#define rst 0
TimeChangeRule myDST = {"EDT", Last , Sun, Mar, 1, +60}; //Daylight time = UTC - 4 hours
TimeChangeRule mySTD = {"EST", Last, Sun, Oct, 1, 0}; //Standard time = UTC - 5 hours
Timezone myTZ(myDST, mySTD);
TimeChangeRule *tcr; //pointer to the time change rule, use to get TZ abbrev
time_t utc, local;
int numberOfSensors = 4;
int lux, power;
float energy;
int RLux = 10;
char a[5];
char tempC[2];
char t[3];
char l[5];
char p[6];
char en[7];
char s[5];
char time[3];
char lastSb[5];
int LastValueSb;
char window = 1; // Saves menu position
unsigned long currentMillis;
unsigned long previousMillis = 0;
unsigned long timer1 = 0;
unsigned long previousMillis2 = 0;
boolean firstTime = true;
boolean flagComplete;
boolean flagProgress = true;
// MORE SHIELD STUFF
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
//int position = 0;
//int dim = 255;
//int bright = 0;
int interval = 1000;
int interval2 = 10000;
//THIS LINE MAY VARY - SEE EXAMPLE SKETCHES FROM SHIELD
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
///////////////GRAPH CONFIGURATIONS///////////////////
int blueDownLineY = tft.height(); //100
int blueUpLineY = 55;//45
int graphUpperLimit = blueUpLineY + 1;
int graphDownerLimit = blueDownLineY - 1;
int graphHeight = blueDownLineY - graphUpperLimit;
int xPos = 0;
int drawHeight;
int drawWidth;
int standby;
int avg;
int sbTime = 10;
int x = 1;
int timer = 0;
int remTimeSec = sbTime - timer;
unsigned long totVal = 0;
int lastVal = 0;
//DEFINITIONS FOR THE JOYSTICK
#define Neutral 0
#define Press 1
#define Up 2
#define Down 3
#define Right 4
#define Left 5
long lastDebounceTime = 0;
boolean flag = true;
boolean change = true;
boolean avgFlag = false;
int sensorVal2;
int sensorPin = 9;
float voltage;
int lastChoiceMillis = 0; // a ultima vez que o pino de saida foi modificado (toggled)
int debounceDelay = 1000;
int number = 0;
int choiceDelay = 200;
int pinReadDelay = 10;
int tempPin = 9;
int powerPin = 10;
Wire.begin();
setSyncProvider(RTC.get); // the function to get the time from the RTC
if (timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
// MORE TFT STUFF - SEE EXAMPLE SKETCHES
tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab
//ROTATES DISPLAY 90 DEGREES FOR LANDSCAPE VIEW
tft.setRotation(3);
// analogWrite(5, 255); //jump "LITE" and Digital pin 5 to dim
// BLANKS OUT THE SCREEN AND DRAWS THE BLACK BAR
tft.fillScreen(YELLOW);
Serial.println(number);
number++;
currentMillis = millis();
if (currentMillis - previousMillis > interval) {
utc = now() + 3600; //- 3600L
printTime(utc, "UTC"); //Prints UTC Time
local = myTZ.toLocal(utc, &tcr);//
printTime(local, tcr -> abbrev); //Prints Local Time
sensorVal2 = analogRead(A2);
voltage = sensorVal2 * 5.0;
voltage /= 1024.0;
if (avgFlag == true) {
totVal += sensorVal2;
avg = (totVal / x);
x++;
timer++;
xPos++;
if (currentMillis - previousMillis2 > interval2) {
//readTemp();
previousMillis2 = currentMillis;
int joy = CheckButton();
switch (window) { // Define checa qual tela atual
case 1: // executado quando na TELA 1
switch (joy)
case Right:
change = true;
Set_window(2);
default: Set_window(1);
case 2: // executado quando na TELA 2
switch (joy) {
case Left:
change = true;
Set_window(1);
case Right:
change = true;
Set_window(3);
default: Set_window(2);
case 3: // executado quando na TELA 3
switch (joy) {
case Left:
change = true;
Set_window(2);
case Right:
change = true;
Set_window(4);
default:;
//Set_window(3);
case 4: // executado quando na TELA 4
switch (joy) {
case Right:
change = true;
Set_window(5);
case Left:
change = true;
Set_window(3);
default:;
(....a bunch of case statements.....don´t need to post her)
case 10: // executado quando na TELA 3
switch (joy) {
case Up:
if (currentMillis - lastChoiceMillis > choiceDelay) {
number++;
//Serial.println(number, 4);
lastChoiceMillis = currentMillis;
case Down:
number--;
if (number < 0) number = 0;
case Right:
number = number * 10;
case Left:
number = number * 0.1;
default: ;
And I don't think I need to show you all of the functions! I think that's not the problem.
Even if I hide the rest of the code in the loop leaving just:
number++;
I notice a break after 1 second..
