Why Timer Arduino not functioning after I add in the function
Hi anyone who can see it. Currently I'm doing a 5 sec countdown timer based project. The coutdown timer will work perfectly alone. However, when I add it in my project, I won't print out the time as 5 sec and it is not moving. Really hope to get your help
Here is the countdown code alone:
LiquidCrystal_I2C lcd(0x27, 16, 2);
long hour = 00, minute = 00, second = 05;//second
long countdown_time = (hour*3600) + (minute * 60) + second;
void timer(){
lcd.init();
lcd.backlight();
lcd.setCursor(4, 0);
lcd.print("HH:MM:SS");
long countdowntime_seconds = countdown_time - (millis() / 1000);
if (countdowntime_seconds >= 0) {
long countdown_hour = countdowntime_seconds / 3600;
long countdown_minute = ((countdowntime_seconds / 60)%60);
long countdown_sec = countdowntime_seconds % 60;
lcd.setCursor(4, 1);
if (countdown_hour < 10) {
lcd.print("0");
lcd.print(countdown_hour);
lcd.print(":");
if (countdown_minute < 10) {
lcd.print("0");
lcd.print(countdown_minute);
lcd.print(":");
if (countdown_sec < 10) {
lcd.print("0");
lcd.print(countdown_sec);
Below is I wanna insert it in the whole project ( I want it countdowns when the light bright up)
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10,11);
#include <Keypad.h>
LiquidCrystal_I2C lcd(0x27,20,4);
char input;
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad inputKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
#include <Servo.h>
int pos = 120;
Servo servo_12;
Servo servo_13;
int RelayPin = 40;
int RelayPin2 = 41;
bool RUN= true;
String v_passcode= "1100";
String v_passcode2= "2200";
void setup(){
Wire.begin();
lcd.begin(20,4);
lcd.init();
lcd.backlight();
pinMode(RelayPin, OUTPUT);
digitalWrite(RelayPin, HIGH);
pinMode(RelayPin2, OUTPUT);
digitalWrite(RelayPin2, HIGH);
mySerial.begin (9600);
servo_12.attach(12, 500, 2500);
servo_13.attach(13, 500, 2500);
intro();
void loop(){
RUN= true;
while (RUN){
input = inputKeypad.getKey();
if (input){
switch (input){
case '1':
rider();
  case '2':
  client();
  default:
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Thank You!");
  lcd.setCursor(0,1);
  lcd.print("Please Try Again!");
  lcd.clear();
  RUN= false;
  intro();
void intro(){
lcd.setCursor(5,1);
lcd.print("Welcome to");
lcd.setCursor(8,2);
lcd.print("SaniC");
delay(6000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" 1. Rider");
lcd.setCursor(0,1);
lcd.print(" 2. Client");
return;
void sendOtpMessage(String tel) {
String msg = "";
msg = "Your OTP is : 1100 From SaniC, Do not share your OTP";
String cmd = "";
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
cmd = "AT+CMGS="" + tel + """;
mySerial.println(cmd);
mySerial.println(msg); // The SMS text you want to send
delay(100);
mySerial.println((char)26); // ASCII code of CTRL + Z
delay(4000);
void sendOtpMessage2(String tel) {
String msg = "";
msg = "Your OTP is : 2200 From SaniC, Do not share your OTP";
String cmd = "";
delay(2000); // Delay of 1000 milli seconds or 1 second
delay(2000);
delay(100);
delay(3000);
void rider(){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter Client TEL:");
lcd.setCursor(0,1);
String tel="+60";
lcd.print(tel);
  int length=0;
  while (length<=11){
    length= tel.length();
    input= inputKeypad.getKey();
    if (input){
      tel= tel+input;
      lcd.setCursor(0,1);
      lcd.print(tel);
  if (length==12){
    delay(6000);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Select Box Size");
    lcd.setCursor(0,1);
    lcd.print("1. Big Box");
    lcd.setCursor(0,2);
    lcd.print("2. Small Box");
   int len=0;
   while (len<1){
    if (input=='1'){
        lcd.clear();
        lcd.setCursor(2,1);
        lcd.print("Door is Opening!");
     for (pos = 45; pos <= 150; pos += 1) {
          servo_12.write(pos);
          delay(15);
        delay(6000);
        for (pos = 150; pos >= 45; pos -= 1) {
          delay(15);
  digitalWrite(RelayPin, LOW);   //light on
  timer();
  delay(5000);
  digitalWrite(RelayPin, HIGH);   //light off while
  sendOtpMessage(tel);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Thank You, See You");
    lcd.clear();
    RUN= false;
    intro();
    if (input=='2'){
        lcd.clear();
        lcd.setCursor(2,1);
          servo_13.write(pos);
          delay(15);
        delay(6000);
          delay(15);
  digitalWrite(RelayPin2, LOW);   //light on
  timer();
  delay(5000);
  digitalWrite(RelayPin2, HIGH);//light off while
    sendOtpMessage2( tel);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.clear();
    RUN= false;
    intro();
void client(){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter the OTP :");
int len2=0;
String passcode= "";
while (len2<=3){
len2= passcode.length();
if (input){
passcode= passcode+input;
lcd.setCursor(0,1);
lcd.print(passcode);
  if (passcode == v_passcode){
     lcd.clear();
     lcd.setCursor(2,1);
          delay(15);
        delay(6000);
          delay(15);
    timer();
    delay(5000);
  digitalWrite(RelayPin, HIGH);//light off while
  if (passcode == v_passcode2){
     lcd.clear();
     lcd.setCursor(2,1);
          delay(15);
        delay(6000);
          delay(15);
    timer();
    delay(5000);
  else if ((passcode!= v_passcode) || (passcode!= v_passcode2)){
    delay(600);
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.print("Password Wrong!");
    lcd.setCursor(4,1);
    lcd.print("Access Failure!");
    lcd.setCursor(2,2);
    lcd.print("Please try again!");
    lcd.clear();
    RUN= false;
    intro();
void timer()
long hour = 00, minute = 00, second = 100;//second
lcd.clear();
lcd.init();
lcd.backlight();
lcd.setCursor(2,0);
lcd.print("Sanitizing");
lcd.setCursor(6,1);
long countdowntime_seconds= countdown_time - (millis()/1000);
while (countdowntime_seconds >0){
long countdown_hour= countdowntime_seconds/ 3600;
long countdown_minute= ((countdowntime_seconds/60) %60);
long countdown_sec = countdowntime_seconds%60;
lcd.setCursor(6,2);
if (countdown_hour<10){
lcd.print("0");
lcd.print(":");
if (countdown_minute <10){
lcd.print("0");
lcd.print(":");
if (countdown_sec <10){
lcd.print("0");
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
You should RE-edit your first post by clicking the pencil-icon
mark your whole code and delete it.
then
post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
loop() is repeatedly called on the Arduino, there's no need for the while loop which only invokes the code to service the keypad.
timer() is invoked within rider() and client() which are only invoked within loop() when specific keys are detected
seems that timer() should be invoked within loop() outside the conditional for input
