Why use int instead of byte for pin numbers?
Well now that we are dissing Arduino, allow me to add my gripes!
Yes, very good, but the design is good enough that they are selling tens of thousands. The good points are that it is aimed at the beginner market, the shields are a useful add-on, and it was an excellent decision to use the open-source g++ compiler.
Compare that to other boards where you have to buy their own (dodgy) compilers, or get a cut-down "beginner" version, and put up with an IDE that is so complex it's almost impossible to get a project up quickly.
Yeah I figure, maybe they weren't the best programmers or engineers but they did create the best, most successful beginner development board and IDE so there's something to be said about that.
@majenko and Krupski
All the above gripes have been posted many times, some even by me. I don't understand many of the design decisions made by Arduino either but the often dubious "features" haven't stopped it becoming a success.
As someone who has never had such a runaway success despite spending a lifetime trying to produce good hardware and software design I find it quite discouraging and another case of both marketing over function and being in the right place at the right time with the right product. Also the fact that most users don't give a rodent's posterior as long as they can get a LED to blink in time with the music :slight_smile:
Rob
Wait, you can get the LEDs to blink in time with music? I must try that ...
...and difficult for beginners to plug in the wrong way round :wink:
Exactly! And that is what was so brilliant about the original design. :slight_smile:
I think it's fair to say that the Arduino is designed for and marketed towards people who don't know any better. Obviously there are people here who can see ways to improve the development environment, runtime library (and its documentation) and the hardware. (No matter how good it was, that would always be the case.) But these are not the people that Arduino targets.
retrolefty:
Yea, many seem to hate all oil companies but still buy their gasoline. :wink:
There is little choice other than to bicycle or walk (both of which are impractical in cold weather and/or long distances).
Krupski:
retrolefty:
There's always running... Gets you warm in cold weather, and gets you further distance in a shorter time.
It also gives you heart attacks and knackered knees.
I'm not saying Arduino is "bad", I just have gripes about the design. The ONLY reason I use Arduino is because of the great GCC support.
The boards, at the very least, should have usable mounting holes. People actually do build REAL projects with Arduino boards and it's ridiculous to either need special plastic standoffs or double sided foam tape to mount the board!
And, the Atmel AVR line certainly isn't the best choice for a microcontroller, but it's good enough for most uses.
I personally prefer the "Motorola" style (von Neumann) CPU architecture. The Harvard / Intel / AVR style architecture is a nightmare to work with. Thankfully, the C libraries shield me from most of that grief...
majenko:
Most of the traces in my left knee are burned open from playing hockey. Running isn't an option for me anymore! :slight_smile:
I can not listen bad about Arduino... I am very thankful to the guys who gave us Free IDE and lot of libraries... And all those are very very simple to use... I love you guys :slight_smile:
The real answer to the original question:
  1. The programmer's time is much more expensive than the computer or compiler's time.
  2. 95% of the time you are not going to need the extra few bytes saved.
  3. The C++ optimizer is so good that it will rarely make any difference in code size anyway.
Two practices that will save some resources were already mentioned by majenko and Krupski in the first page of this thread:
const int instead of int for constants will some a couple bytes,
and Serial.print(F("string const")); instead of Serial.print("string const");
The latter will use more flash, but save RAM. Conservation of RAM is usually a bigger concern than conversation of flash, in my experience. If your code starts acting flaky you are probably running out of RAM, not flash.
-transfinite
transfinite:
The latter will use more flash...
By a constant eight bytes for the entire sketch. Hardly worth mentioning. :wink:
Ah but don't you know? Everyone's sketch compiles to 32767 bytes and not a single one more will fit! (the reason for crippling sprintf and sscanf for floating point).
/saracsm off.
Khalid:
you mean the wiring guys?
]:slight_smile:
Osgeld:
Khalid:
]:slight_smile:
http://wiring.org.co/
Sure, along with the AVRDUDE guys, the gcc guys, the processing guys, and the java guys (I'm probably leaving others out?). The arduino platform design stands on the shoulders of many open source projects, it wasn't designed in a vacuum or a ground up effort, more like assembled from many other's open source contributions.
I think arduino's main unique contribution was their decision to open source their hardware design also which really spurred on a strong 3rd party 'compatible' and shield market that few other hardware/software micro-controller enjoy.
Lefty
stoopkid:
Why do we use:
int led = 13;
instead of
byte led = 13;
If you would never need to define more than 256 pins, why use the extra space for int? Is there a reason?
Thanks.
That's what I do. 2k ram really isn't much, and then you try an ATtiny....
Krupski:
An "int" is an unsigned 16 bit variable (uses two bytes of memory).
Type int has always been signed in every version of C or C++ I ever used, including Arduino.
krupski:
A "byte" type is the same as "uint8_t" (uses one byte of memory). An "int" is an unsigned 16 bit variable (uses two bytes of memory).
Thanks krupski, for this informative answer. After going back to it now, I see this info is in the reference data, but I didn't absorb it like I did in your statement.
