I can successfully connect a Nokia display to a ESP6288 when, in the IDE I specify the board as 'NodeMCU 1.0(ESP 12E)'
But when I try running the same code on a WeMos specifying board as 'WeMos D1 R1'. it fails to compile.
I thought the ESP6288 and WeMos are essentially the same microcontroller. If so is this a problem with the IDE ??? The library I'm using is for the Nokia is Adafruit_PCD8544.h
So there are errors? Why not share the errors and the code so that we can help?
Read the how to use this forum-please read sticky to see how to properly post code and errors. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
what processor board do you really have? Please provide a clickable link!
Maybe you could try to compile for LOLIN(Wemos) D1 R2 & mini.
Jean-Marc
Thankyou so much Jean-Marc you were correct.
I'm new to WeMos and initially tried WeMos D1 R1 and it worked with simple applications like Blynk so I thought that was the correct option.
I now see with the clone that I've purchased off eBay that LOLIN(Wemos) D1 R2 & mini is correct choice.
Thanks also to groungFungus for your prompt response
