Hello. I am currently programming a project that uses a switch to control an LED and 2 servos. I want the LED to be steadily on throughout the entire duration of my servo motion but want the LED to turn off once both servos stop moving. Below is my code, why is my low digital write at the end not working for this task?
#include<Servo.h>// include servo library
Servo myservo1;
Servo myservo2;
int POWERON = 6; //switch in position 6 will power on system
int LED = 5; //LED is in pin 5
myservo1.attach(10); //Servo 1 is attached to pin 10
myservo2.attach(9); //Servo 2 is attached to pin 9
pinMode(POWERON, INPUT_PULLUP);
//pinMode(POWEROFF,INPUT);
pinMode(LED, OUTPUT);
if (digitalRead(POWERON) == HIGH)
digitalWrite(LED, HIGH);
myservo1.write(45);
delay(3000);
myservo1.write(0);
for (byte times = 0; times < 30; times++){
myservo2.write(0);
myservo2.write(180);
digitalWrite(LED, LOW);
Servo myservo1;
Servo myservo2;
myservo1.write(45);
delay(3000);
myservo1.write(0);
myservo2.write(0);
[/quote]
Servo myservo1;
Servo myservo2;
myservo1.write(45);
delay(3000);
myservo1.write(0);
myservo2.write(0);
I took your original code, changed the LED to 13 to use the onboard LED, and added some Serial.prints to see that it was not freezing up. It compiles fine and the LED turns on and off as expected.
Servo myservo1;
Servo myservo2;
int LED = 13; //LED is in pin 5
myservo1.write(45);
Serial.print(".");
delay(3000);
myservo1.write(0);
Serial.print(".");
myservo2.write(0);
Serial.print(".");
Serial.print(".");
Serial.print("done");
Perhaps there is something not correct about pin 5 wiring. Do you have a current limit resistor in series with the LED?
