Why won't it work?: line following RC car
I am working on a project for science fair that involves a toy car. It will have a pololu QTR-8RC reflectance array that will be the input. There will be two DC motors, one in the front for steering, another in the back to make the car go. When I upload the code to the Uno, it shows no errors. But the car does nothing. I was wandering if someone could spot something wrong with my code.
Here it is:
[/code#include <QTRSensors.h> // using Sensor Library
 // Sensor settings
 #define NUM_SENSORS             6
 #define NUM_SAMPLES_PER_SENSOR  4
 #define EMITTER_PIN             2
 QTRSensorsAnalog qtra((unsigned char[]) {0, 1, 2, 3, 4, 5},
  NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN);
 unsigned int sensorValues[NUM_SENSORS];
 // Set variables
int
PWM_A   = 3,  //This is the power for channel A or the front motor
DIR_A   = 12,//Direction A is digital pin 12. It is the direction for channel A
DIR_B  = 10,
BRAKE_B = 8,
BRAKE_A = 9;  //Brake A is digital pin 3. It is the brake for the steering motor
const int
carSpeed = 125,
PWM_B   = 13,
steerSpeed = 255;
// Setup
  //Setup Channel A as Front Motor (Turning)
  pinMode(PWM_A, OUTPUT); //Initiates Motor Channel A pin
  pinMode(BRAKE_A, OUTPUT); //Initiates Brake Channel A pin
  pinMode(DIR_A, OUTPUT);//Initiates Direction Channel A pin
  //Setup Channel B as Rear Motor (speed)
  pinMode(PWM_B, OUTPUT); //Initiates Motor Channel A pin
  pinMode(BRAKE_B, OUTPUT);  //Initiates Brake Channel A pin
  pinMode(DIR_B, OUTPUT);
  // for (int i = 0; i < 250; i++)  // make the calibration take about 10 seconds
  // setup monitor
    Serial.begin(9600); //Show data on screen
    qtra.calibrate();  // reads all sensors 10 times at 2500 us per read (i.e. ~25 ms per call)
    int carPosition = qtra.readLine(sensorValues);    // get sensor reading
    digitalWrite(10, HIGH);
    digitalWrite(8, LOW);
    digitalWrite(3, carSpeed);
    unsigned int position = qtra.readLine(sensorValues);
    unsigned int sensorValues[3];
    int line = carPosition - 1000;  // line = position of line
    // turning the car based on sensor reading
    if (line = 500)  //If line is straight,
    { (BRAKE_A, HIGH);  //Brake for channel A is high so it doesn't turn
   if (line > 500)  //if line is on right
   { analogWrite(BRAKE_A, LOW);  // setting brake LOW disable motor brake
  analogWrite(DIR_A, HIGH);   // setting direction to HIGH the motor will spin forward and the car will turn right
  analogWrite(PWM_A, steerSpeed);
   if (line < -500)
   {digitalWrite(BRAKE_A, LOW);  // setting againg the brake LOW to disable motor brake
  digitalWrite(DIR_A, LOW);    // setting direction to Low the motor will spin backwards and the car will turn left
  digitalWrite(PWM_A, steerSpeed);     // Set the speed of the motor
   // Monitor
    //Serial.print();
    Serial.println(carSpeed);
    Serial.print("\t");
    Serial.println(steerSpeed);
    Serial.print("\t");
    Serial.println(line);
    Serial.print("\t");
    Serial.println(carPosition);
    Serial.print("\t");
    Serial.println("");
Please help, I have been working on this forever and it is getting frustrating.
In your other thread on this exact topic, it was pointed out that....
if (line = 500)
.... is wrong, yet that's still in your code.
It should have == not =, as explained here under the heading "Warning".
I also asked you there, if the serial prints indicated that the sensors were giving the correct values. Are they?
So’s the other stuff pointed out.
Thread locked - post answers here
DO NOT CROSS-POST, CROSS-POSTING WASTES TIME.
