Anyone familiar with Twilio or Temboo? It's a free online text message sending service.
My arduino (atmega) isn't getting a DHCP response. I can fix this issue, but it requires me to delete a section of code that should have nothing to do with the arduino to router connection.
Here's the code:
#include <SPI.h>
#include <DhcpV2_0.h>
#include <DnsV2_0.h>
#include <EthernetV2_0.h>
#include <EthernetClientV2_0.h>
#include <Temboo.h>
#include "TembooAccount.h" // Contains Temboo account information
byte ethernetMACAddress[] = ETHERNET_SHIELD_MAC;
EthernetClient client;
int numRuns = 1; // Execution count, so this doesn't run forever
int maxRuns = 10; // Maximum number of times the Choreo should be executed
// For debugging, wait until the serial console is connected
delay(4000);
while(!Serial);
Serial.print("DHCP:");
if (Ethernet.begin(ethernetMACAddress) == 0) {
Serial.println("FAIL");
while(true);
Serial.println("OK");
delay(5000);
Serial.println("Setup complete.\n");
if (numRuns <= maxRuns) {
Serial.println("Running SendSMS - Run #" + String(numRuns++));
TembooChoreo SendSMSChoreo(client);
// Invoke the Temboo client
SendSMSChoreo.begin();
// Set Temboo account credentials
SendSMSChoreo.setAccountName(TEMBOO_ACCOUNT);
SendSMSChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
SendSMSChoreo.setAppKey(TEMBOO_APP_KEY);
// Set Choreo inputs
String AuthTokenValue = "";
SendSMSChoreo.addInput("AuthToken", AuthTokenValue);
String ToValue = "";
SendSMSChoreo.addInput("To", ToValue);
String FromValue = "";
SendSMSChoreo.addInput("From", FromValue);
String BodyValue = "testing testing";
SendSMSChoreo.addInput("Body", BodyValue);
String AccountSIDValue = ;
SendSMSChoreo.addInput("AccountSID", AccountSIDValue);
// Identify the Choreo to run
SendSMSChoreo.setChoreo("/Library/Twilio/SMSMessages/SendSMS");
// Run the Choreo; when results are available, print them to serial
SendSMSChoreo.run();
while(SendSMSChoreo.available()) {
char c = SendSMSChoreo.read();
Serial.print(c);
SendSMSChoreo.close();
Serial.println("\nWaiting...\n");
delay(30000); // wait 30 seconds between SendSMS calls
(credentials were taken out)
and i get the following error:
DHCP:FAIL
When I take out the section between the ####.. (the credentials).. the DHCP works fine, but this section should have nothing to do with the connection between the router and me...
anyway, when I take that section out, the DHCP goes through, but I of course get the following error:
DHCP:OK
Setup complete.
Running SendSMS - Run #1
HTTP_CODE
500
Server Error
content-type: text/plain
Date: Wed, 06 Jan 2016 10:58:36 GMT
Server: Jetty(8.1.7.v20120910)
Connection: Close
Error
A Step Error has occurred: "An input error has occurred. AccountSID, AuthToken, From, and To are required. You must also provide at least one of the following parameters: Body or MediaURL.". The error occurred in the Stop (Stop) step.
Waiting...
