Why won't my function script work?
Here is the code
void strToCharArr(String sn) {
String snan=sn+F("sa");
int sca=sn.length()+1;
sn.toCharArray(snan[sca],sca);
But whenever I run it I get this
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Due (Programming Port)"
C:\Users*****\Documents\Arduino\testMem\testMem.ino: In function 'void strToCharArr(String)':
testMem:20:31: error: invalid conversion from 'char' to 'char*' [-fpermissive]
In file included from C:\Users*****\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\cores\arduino/Arduino.h:192:0,
from sketch\testMem.ino.cpp:1:
C:\Users****\Documents\ArduinoData\packages\arduino\hardware\sam\1.6.12\cores\arduino/WString.h:161:7: error: initializing argument 1 of 'void String::toCharArray(char, unsigned int, unsigned int) const' [-fpermissive]
void toCharArray(char *buf, unsigned int bufsize, unsigned int index=0) const
exit status 1
Could someone explain what I'm doing wrong? I'm trying to make it so you can make a string array by only typing a string name. I'm running this on an arduino due, but I don't know if that is the problem.
Not really sure what you're trying to do, but the issue is that toCharArray expects a pointer to a char array as it's first parameter but scan[sca] is a char.
wildbill:
There is no scan[sca] in my code so I don't know what you are talking about
I'm trying to tell it to make snan[sca] the character array
micahsuess:
snan[sca] is a single char, not an array.
Also I would recommend you to not use Arduino strings in the future...
wildbill:
Do you know how I could make it go into an array?
TheUNOGuy:
Yes I know, that's why I'm trying to turn the string into a character array so I can \0 the string
But this is helpful
there is a library called PString which you can install from the library-manager.
PStrings are based on array of chars and bring back a part of the comofrt of strings but without the "eat-up-all-memory-problem"
here is a democode that extracts substrings from a long PString
#include <PString.h>
char    XML_Str_AoC[256] = " ";
PString XML_Str_PS(XML_Str_AoC, sizeof(XML_Str_AoC));
char    XML_SubStr_AoC[256] = " ";
PString XML_SubStr_PS(XML_SubStr_AoC, sizeof(XML_SubStr_AoC));
char    Value_AoC[32] = " ";
PString Value_PS(Value_AoC, sizeof(Value_AoC));
char    IDStr_AoC[32] = "=";
PString IDStr_PS(IDStr_AoC, sizeof(IDStr_AoC));
char    Separator_AoC[32] = "=";
PString Separator_PS(Separator_AoC, sizeof(Separator_AoC));
unsigned long IDPos;
unsigned long ValuePos;
unsigned long EndOfValuePos;
unsigned long StrLen;
unsigned long BeginOfSubStr (char* p_PointerToSource, char* p_PointerToSubStr) {
  unsigned long result = strstr(p_PointerToSource,p_PointerToSubStr) - p_PointerToSource;
  return result;
unsigned long EndOfSubStr (char* p_PointerToSource, char* p_PointerToSubStr) {
  unsigned long result = strstr(p_PointerToSource,p_PointerToSubStr) - p_PointerToSource + strlen(p_PointerToSubStr);
  return result;
// my personal naming-convention parameter of functions start with prefix "p_"
void ExtractUntilSeparator(char* p_PointerToTarget, char* p_PointerToSeparator, char* p_PointerToSource)
  Serial.println("entering ExtractUntilSeparator");
  unsigned int LengthUntilDelimiter = strstr(p_PointerToSource,p_PointerToSeparator) - p_PointerToSource + 1;
  // attention use the command strlcpy with care. strlcpy perfoms a direct write into RAM at the given adress
  // the compiler has no chance to check if your adress makes sense
  // the writing is done mercyless to the given adress. This means wrong pointer-adress leads to unpredictable bugs
  strlcpy(p_PointerToTarget,p_PointerToSource,LengthUntilDelimiter);
  Serial.print("p_PointerToSource:>#");
  Serial.print(p_PointerToSource);
  Serial.println("#");
  Serial.print("p_PointerToTarget:>#");
  Serial.print(p_PointerToTarget);
  Serial.print("p_PointerToSeparator:>#");
  Serial.print(p_PointerToSeparator);
  Serial.println("leaving ExtractUntilSeparator");
// my personal naming-convention parameter of functions start with "p_"
void ExtractValueBehindSeparator(char* p_PointerToTarget, char* p_PointerToSeparator, char* p_PointerToSource)
  Serial.println("entering ExtractValueBehindSeparator");
  unsigned int PosOfSeparatorEnd = strstr(p_PointerToSource,p_PointerToSeparator) - p_PointerToSource + strlen(p_PointerToSeparator);
  // if separatorstring was  found
  if (PosOfSeparatorEnd < strlen(p_PointerToSource) )
    Serial.print("PosOfSeparatorEnd:>#");
    Serial.print(PosOfSeparatorEnd);
    unsigned int NoOfBytesUntilEoString = strlen (p_PointerToSource) - PosOfSeparatorEnd + 1;
    strlcpy(p_PointerToTarget, p_PointerToSource + PosOfSeparatorEnd, NoOfBytesUntilEoString);
    p_PointerToTarget = ""; // if no separator was found there is nothing behind the separator
  Serial.println("leaving ExtractValueBehindSeparator");
  Serial.println("setup-Start");
  XML_Str_PS += "HTTP/1.0 200 OK ";
  XML_Str_PS += "Content-Type: text/xml ";
  XML_Str_PS += "Access-Control-Allow-Origin: * ";
  XML_Str_PS += "X-Frame-Options: SAMEORIGIN ";
  XML_Str_PS += "X-Content-Type-Options: nosniff ";
  XML_Str_PS += "X-XSS-Protection: 1; mode=block ";
  XML_Str_PS += "X-Robots-Tag: none ";
  XML_Str_PS += "X-Download-Options: noopen ";
  XML_Str_PS += "X-Permitted-Cross-Domain-Policies: none ";
  XML_Str_PS += "Referrer-Policy: no-referrer ";
  XML_Str_PS += "Content-Length: 300 ";
  XML_Str_PS += "Connection: close ";
  XML_Str_PS += "Date: Fri, 19 Jun 2020 20:20:38 GMT ";
  XML_Str_PS += "<?xml version='1.0' encoding='ISO-8859-1' ?><systemVariables><systemVariable name='Grube Stand' variable='3.000000' value='3.000000' value_list='' value_text='' ise_id='2632' min='0' max='65000' unit='cm' type='4' subtype='0' timestamp='1592598038' value_name_0='' value_name_1=''/></systemVariables>";
  Serial.print("XML_Str_PS#");
  Serial.print(XML_Str_PS);
  Serial.print("#");
  IDStr_PS = "'Grube Stand'";
  Serial.print("1: IDStr_PS#");
  Serial.print(IDStr_PS);
  Serial.print("#");
  IDPos = BeginOfSubStr(XML_Str_PS,IDStr_PS);
  Serial.print("IDPos:");
  Serial.print(IDPos);
  Serial.print("#");
  IDStr_PS = "value_list=";
  Serial.print("2:IDStr_PS#");
  Serial.print("#");
  ValuePos = BeginOfSubStr(XML_Str_AoC,IDStr_AoC);
  Serial.print("#");
  Serial.print("ValuePos:");
  Serial.print(ValuePos);
  Serial.print("#");
  StrLen = ValuePos - IDPos;
  Serial.print("StrLen:");
  Serial.print(StrLen);
  Serial.print("#");
//Grube Stand' variable='3.000000' value='3.000000'
  // attention use the command strncpy with care. strncpy perfoms a direct write into RAM at the given adress
  strncpy(XML_SubStr_PS,  XML_Str_PS + IDPos, StrLen);
  Serial.print("SubStr#");
  Serial.print(XML_SubStr_PS);
  Serial.print("#");
  XML_Str_PS = XML_SubStr_PS;
  Separator_PS = "value='";
  IDPos = EndOfSubStr(XML_SubStr_PS,Separator_PS);
  Serial.print("3: IDPos:");
  Serial.print("#");
  StrLen = strlen(XML_Str_PS) - IDPos + 1;
  Serial.print("#");
  Serial.print("#");
  Separator_PS = "'";
  ExtractUntilSeparator(XML_SubStr_PS, Separator_PS, XML_Str_PS);
  Serial.print("value SubStr#");
  Serial.print("#");
best regards Stefan
micahsuess:
But this is helpful
A string is a character array.
