why won't my loop return to knappstate (LOW)?
please help me. I can't figure out what's wrong. at first the knappstate is LOW and when I push the button I go to knappstate HIGH. so far its working. but when I release the button everything stops. what's wrong with the code? please help >:(
#include <Volume3.h>
#include <TimerOne.h>
const int led = 13;
const int pitch = A0; // sensor pinne
const int volym = A1; // sensor pinne
const int bpm = A2; // sensor pinne
const int knapp = 2; // ledpinne
const int ljud = 9; //högtalarpinne
int rattValue = 0; //värdet som lagras när sensorn läst av ljusstyrkan
int volymValue = 0; //värdet som lagras när sensorn läst av ljusstyrkan
int knappState = 0;
int ledState = 0;
int ljudState = 0;
int tempo;
long previousMillis = 0;
long interval = 1000;
Serial.begin(9600); pinMode(led, OUTPUT); pinMode(ljud, OUTPUT); pinMode(knapp, INPUT);
knappState = digitalRead(knapp);
if (knappState == LOW) {
int pitchValue = analogRead(pitch); Serial.println(pitchValue);
int thisPitch = map(pitchValue, 1023, 0, 880, 110);
int volymValue = analogRead(volym); Serial.println(volymValue);
int thisLoud = map(volymValue, 1023, 0, 1000, 0);
int bpmValue = analogRead(bpm); Serial.println(bpmValue);
int tempo = map(bpmValue, 1023, 0, 560, 80);
vol.tone(ljud, thisPitch, thisLoud);
int interval = (1000/tempo)*60; //algorithm to convert tempo into BPM
if(currentMillis - previousMillis >= interval) {
if (ledState == 0)
digitalWrite(led, HIGH);
} else
ledState = 0;
digitalWrite(led, LOW);
if (knappState == HIGH) {
if (ljudState == 0)
} else
ljudState = 0;
digitalWrite(led, LOW);}
Before posting, please use the IDE's auto format tool, and use code tags when you do post the formatted code.
@bigcalle
Moved your topic to it's current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Floating input for knapp?
Set pinMode for knapp to INPUT_PULLUP, then swap your checks for knappState from LOW to HIGH and vice versa.
