I am currently working on setting up an ethernet shield connected arduino that posts information obtained from a dust sensor to pachtube. Im pretty sure that the non-pachtube related stuff works fine as ive tested it out by just making it post information via serial, but for some reason I cannot get it to post to pachtube at all, although it does not give me a "connection failed" message. If someone could point out what I am doing wrong here I would really appreciate it as I am clueless as to what I can do to fix this problem at this point in time, thanks! also for the actual project example I am referencing from, here is the url http://www.howmuchsnow.com/arduino/airquality/grovedust/. Below is the code, I have altered the Key for pachtube of course, but the feed ID is the same.
Interface to Shinyei Model PPD42NS Particle Sensor
Program by Christopher Nafis
Written April 2012
http://www.seeedstudio.com/depot/grove-dust-sensor-p-1050.html
http://www.sca-shinyei.com/pdf/PPD42NS.pdf
JST Pin 1 (Black Wire) => Arduino GND
JST Pin 3 (Red wire) => Arduino 5VDC
JST Pin 4 (Yellow wire) => Arduino Digital Pin 8
#include <SPI.h>
#include <Ethernet.h>
#include <stdlib.h>
byte mac[] = {
0x90, 0xA2, 0xDA, 0x0D, 0x27, 0xBF};
IPAddress ip(192,168,1,89);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255, 255, 255, 0);
// initialize the library instance:
EthernetClient client;
long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
boolean lastConnected = false; // state of the connection last time through the main loop
const int postingInterval = 10000; //delay between updates to Pachube.com
int pin = 8;
//int ledPin = 13;
//int ledPin2 = 12;
unsigned long duration;
unsigned long starttime;
unsigned long sampletime_ms = 30000;
unsigned long lowpulseoccupancy = 0;
float ratio = 0;
float concentration = 0;
char s[32];
void setup(){
// give the ethernet module time to boot up:
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Configure manually:
Ethernet.begin(mac, ip);
pinMode(8,INPUT);
starttime = millis();
//pinMode(ledPin, OUTPUT);
//pinMode(ledPin2, OUTPUT);
//digitalWrite(ledPin, HIGH);
//digitalWrite(ledPin2, LOW);
void loop(){
duration = pulseIn(pin, LOW);
lowpulseoccupancy = lowpulseoccupancy+duration;
if ((millis()-starttime) > sampletime_ms)
//digitalWrite(ledPin2, HIGH);
//digitalWrite(ledPin, LOW);
//delay(1000);
ratio = lowpulseoccupancy/(sampletime_ms*10.0); // Integer percentage 0=>100
concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62;
Serial.print(lowpulseoccupancy);
Serial.print(",");
Serial.print(ratio);
Serial.print(",");
Serial.println(concentration);
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
//Serial.print(c);
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
Serial.println("disconnecting.");
client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
String dataString = "";
dataString += dtostrf(concentration, 9, 4, s);
dataString += ",";
dataString += dtostrf(ratio, 9, 4, s);
sendData(dataString);
Serial.println(dataString);
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(String thisData) {
// if there's a successful connection:
if (client.connect("www.pachube.com", 80)) {
Serial.println("connecting...");
// send the HTTP PUT request.
// fill in your feed address here:
client.print("PUT /api/67259.csv HTTP/1.1\n");
client.print("Host: www.pachube.com\n");
// fill in your Pachube API key here:
client.print("X-PachubeApiKey: LAjqaUq0e_btR9dMaOWuSGJS766SAKxuS3lISlBvT0dOVT0g\n");
client.print("Content-Length: ");
client.println(thisData.length(), DEC);
// last pieces of the HTTP PUT request:
client.print("Content-Type: text/csv\n");
client.println("Connection: close\n");
// here's the actual content of the PUT request:
client.println(thisData);
// note the time that the connection was made:
lastConnectionTime = millis();
else {
// if you couldn't make a connection:
Serial.println("connection failed");
