Hey Tom
Im using arduino uno, a rotary encoder is my controller. i haven really noted up all the rest but im basicly making a menu system. One section is LEDS i have working, i had the second song working fine but the code above is the isue in the //***** box. Its quite big i apologize, i also only have 36 hrs experience so you might cringe looking at it :D.
Thanks in advance
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
#include "pitches.h"
// Defining frequency of each music note
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
// Music notes of the song, 0 is a rest/pulse
int notes[] = {
NOTE_E4, NOTE_G4, NOTE_A4, NOTE_A4, 0,
NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, 0,
NOTE_C5, NOTE_D5, NOTE_B4, NOTE_B4, 0,
NOTE_A4, NOTE_G4, NOTE_A4, 0,
NOTE_A4, NOTE_C5, NOTE_D5, NOTE_D5, 0,
NOTE_D5, NOTE_E5, NOTE_F5, NOTE_F5, 0,
NOTE_E5, NOTE_D5, NOTE_E5, NOTE_A4, 0,
NOTE_A4, NOTE_C5, NOTE_B4, NOTE_B4, 0,
NOTE_C5, NOTE_A4, NOTE_B4, 0,
NOTE_A4, NOTE_A4,
//Repeat of first part
//End of Repeat
NOTE_E5, 0, 0, NOTE_F5, 0, 0,
NOTE_E5, NOTE_E5, 0, NOTE_G5, 0, NOTE_E5, NOTE_D5, 0, 0,
NOTE_D5, 0, 0, NOTE_C5, 0, 0,
NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4,
NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4};
// Durations (in ms) of each music note of the song
// Quarter Note is 250 ms when songSpeed = 1.0
int durations[] = {
125, 125, 250, 125, 125,
125, 125, 375, 125,
125, 125, 375, 125,
125, 125, 125, 250, 125,
250, 125, 250, 125,
125, 125, 375, 375,
250, 125,
//Rpeat of First Part
125, 125, 375, 125,
125, 125, 375, 125,
250, 125, 250, 125,
125, 125, 375, 375,
//End of Repeat
250, 125, 375, 250, 125, 375,
125, 125, 125, 125, 125, 125, 125, 125, 375,
125, 125, 125, 125, 125, 500,
125, 125, 125, 125, 125, 500};
int melody[] = {
NOTE_G4, NOTE_C5, NOTE_G4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_E4,
NOTE_A4, NOTE_G4, NOTE_F4, NOTE_G4, NOTE_C4, NOTE_C4,
NOTE_D4, NOTE_D4, NOTE_E4, NOTE_F4, NOTE_F4, NOTE_G4, NOTE_A4, NOTE_B4, NOTE_C5, NOTE_D5,
NOTE_E5, NOTE_D5, NOTE_C5, NOTE_D5, NOTE_B4, NOTE_G4,
NOTE_C5, NOTE_B4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_E4,
NOTE_C5, NOTE_B4, NOTE_A4, NOTE_G4, NOTE_B4, NOTE_C5, NOTE_D5,
NOTE_E5, NOTE_D5, NOTE_C5, NOTE_B4, NOTE_C5, NOTE_D5, NOTE_G4, NOTE_G4, NOTE_B4, NOTE_C5, NOTE_D5,
NOTE_C5, NOTE_B4, NOTE_A4, NOTE_G4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_E4, NOTE_G4, NOTE_A4, NOTE_B4,
NOTE_C5, NOTE_A4, NOTE_B4, NOTE_C5, NOTE_A4, NOTE_B4, NOTE_C5, NOTE_A4, NOTE_C5, NOTE_F5,
NOTE_F5, NOTE_E5, NOTE_D5, NOTE_C5, NOTE_D5, NOTE_E5, NOTE_C5, NOTE_C5,
NOTE_D5, NOTE_C5, NOTE_B4, NOTE_A4, NOTE_B4, NOTE_C5, NOTE_A4, NOTE_A4,
NOTE_C5, NOTE_B4, NOTE_A4, NOTE_G4, NOTE_C4, NOTE_G4, NOTE_A4, NOTE_B4, NOTE_C5
int noteDurations[] = {
8, 4, 6, 16, 4, 8, 8,
4, 6, 16, 4, 8, 8,
4, 8, 8, 4, 8, 8, 4, 8, 8, 2,
4, 6, 16, 4, 8, 8,
4, 6, 16, 4, 8, 8,
4, 6, 16, 4, 6, 16,
4, 6, 16, 8, 8, 8, 8,
2, 8, 8, 8, 8, 3, 8, 8, 8, 8, 8,
4, 6, 16, 4, 6, 16, 4, 8, 8, 2,
2, 8, 8, 8, 8, 3, 8, 2,
4, 6, 16, 4, 4, 2, 4, 4, 1
const float songSpeed = 1.0;
#define redLED 6
#define greenLED 5
#define blueLED 13
int red = 6; //select the pin for the red LED
int green =5;// select the pin for the green LED
int blue =13; // select the pin for the blue LED
int CLK = 2;//CLK->D2
int DT = 3;//DT->D3
int SW = 4;//SW->D4
const int interrupt0 = 0;// Interrupt 0 ε¨ pin 2 δΈ
int count = 0;//Define the count
int lastCLK = 0;//CLK initial value
int btn = 1;
int btncount;
int buzzerPin = A3;
pinMode(btn,INPUT);
//RGB LED set as output
pinMode(redLED,OUTPUT);
pinMode(greenLED,OUTPUT);
pinMode(blueLED,OUTPUT);
digitalWrite(redLED,LOW);
digitalWrite(greenLED,LOW);
digitalWrite(blueLED,LOW);
pinMode(btn, INPUT);
pinMode(buzzerPin, OUTPUT);
noTone(buzzerPin);
pinMode(SW, INPUT);
analogWrite(SW, HIGH);
pinMode(CLK, INPUT);
pinMode(DT, INPUT);
attachInterrupt(interrupt0, ClockChanged, CHANGE);//Set the interrupt 0 handler, trigger level change
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.setCursor(5, 1);
lcd.print("start");
delay(5000);
lcd.clear();
lcd.setCursor(4, 1);
lcd.print("welcome");
delay(2000);
count = 15;
if(count <= 29 && count >= 15)
lcd.setCursor(6, 0);
lcd.print("Menu");
lcd.setCursor(0, 1);
lcd.print("30= LED 13=Song");
lcd.clear();
if(count <= 14 && count >=8)
lcd.print("Menu");
lcd.print("6=cccp 8=pirate");
//lcd.clear();
// delay(500);
if ( count != 8 ) return;
if( count == 8)
const int totalNotes = sizeof(notes) / sizeof(int);
// Loop through each note
for (int i = 0; i < totalNotes; i++)
const int currentNote = notes[i];
float wait = durations[i] / songSpeed;
// Play tone if currentNote is not 0 frequency, otherwise pause (noTone)
if (currentNote != 0)
tone(buzzerPin, notes[i], wait); // tone(pin, frequency, duration)
if ( count != 8 )
// Break from loop once button is released
lcd.print(count);
noTone(buzzerPin);
// delay is used to wait for tone to finish playing before moving to next loop
delay(wait);
// Skip rest of code if not truet pressed
if ( count != 6 ) return;
if( count == 6)
// Execute once button has been released
for ( int thisNote = 0; thisNote < sizeof( melody ) / 2; thisNote++ )
int noteDuration = 2000 / noteDurations[thisNote];
tone( buzzerPin, melody[thisNote], noteDuration );
digitalWrite(redLED,HIGH);
int pauseBetweenNotes = noteDuration * 1.30;
delay( pauseBetweenNotes );
// Check for a button press
if ( count != 6 )
lcd.print(count);
if(count >= 29){
lcd.setCursor(3, 0);
lcd.print("LED menu");
delay(3000);
lcd.clear();
lcd.print("39 for red");
delay(3000);
lcd.clear();
if (count == 39){
while (count == 39){
lcd.print("red");
lcd.setCursor(0, 0);
lcd.print("49 for green");
delay(3000);
lcd.clear();
if (count == 49) {
while (count == 49){
lcd.print("green");
digitalWrite(greenLED,HIGH);
lcd.setCursor(1, 1);
lcd.print("49 for blue");
delay(3000);
lcd.clear();
if (count == 59 ) {
while (count == 59){
lcd.print("blue");
digitalWrite(blueLED,HIGH);
lcd.print("69 for purple");
delay(3000);
lcd.clear();
if (count == 69 ) {
while (count == 69){
lcd.print("Purple");
lcd.print("79 for white");
delay(3000);
lcd.clear();
if (count == 79) {
while (count == 79){
lcd.print("White");
lcd.print("99 to menu");
delay(3000);
lcd.clear();
if (count >= 99) {
while (count >= 99){
lcd.print("going back");
delay(4000);
count = 0;
lcd.clear();
return;
//The interrupt handlers
void ClockChanged()
int clkValue = digitalRead(CLK);//Read the CLK pin level
int dtValue = digitalRead(DT);//Read the DT pin level
if (lastCLK != clkValue)
lastCLK = clkValue;
count += (clkValue != dtValue ? 1 : -1);//CLK and inconsistent DT + 1, otherwise - 1
lcd.clear();
lcd.print(count);
