The Wi-Fi shield is terribly greedy when it comes to power consumption. I need a way to utilize Wi-Fi when needed, but can't afford the regular power consumption.
Solution: I want to put the Wi-Fi shield on a breadboard, and connect it through wires to the arduino. I want to incorporated a normally open relay, which only allows power to go to the Wi-Fi shield when the relay is "charged".
My question are:
Which pin do I target? When I refer to pin, I am referring to the male end of the Wi-Fi shield that is made to insert into the female end of the arduino. Would it be the male pin that goes into the 5v pin on the arduino?
Will this work? or will the Wi-Fi code itself use the power even if the wi-fi shield wasn't attached?
Is there a way to do this using code only without a relay?
By the way, is there like a contest for arduino that users can summit prototype designs on youtube or something, and the winner chosen is awarded the resources to make the prototype power and size efficient to get it to market, or at least to impress investors?
Respectfully,
Thomas
