wi-shiled doesn't works in infra mode
hi, i am connected my wi-shiled’s wifi signal to my laptop wifi in adhoc mode. but when i program with infra mode, my wi-shiled indicator led itself not glowing and i couldnt see my wishiled’s wifi signal name in my laptop.
And also i couldnt set the security WEP or WPA, WPA-2.
please help me to connect with the security and also to connect to my android phone.
  • A simple sketch that uses WiServer to serve a web page
#include <WiServer.h>
#define WIRELESS_MODE_INFRA 1
#define WIRELESS_MODE_ADHOC 2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip = {192,168,43,9}; // IP address of WiShield
unsigned char gateway_ip = {192,168,43,1}; // router or gateway IP address
unsigned char subnet_mask = {255,255,255,0}; // subnet mask for the local network
const prog_char ssid PROGMEM = {“androidAP7925”}; // max 32 bytes
int ON, OFF;
unsigned char security_type = 0; // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase PROGMEM = {“12345678”}; // max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, // Key 0
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 1
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 2
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_ADHOC;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters ----------------------------------------
// This is our page serving function that generates web pages
boolean sendMyPage(char* URL) {
// Check if the requested URL matches “/”
if (strcmp(URL, “/”) == 0) {
WiServer.print("");
WiServer.print(“hi”);
WiServer.print("");
return true;
WiServer.init(sendMyPage);
Serial.begin(57600);
WiServer.enableVerboseMode(true);
void loop(){
// Run WiServer
WiServer.server_task();
hi, i am connected my wi-shiled's wifi signal to my laptop wifi in adhoc mode. but when i program with infra mode, my wi-shiled indicator led itself not glowing and i couldnt see my wishiled's wifi signal name in my laptop.
The physic took the summer off. We don't play guessing games without the physic to give us a fair chance.
Which WiFi shield are you talking about?
wi-shield 2.0 is what i am using.
31 posts and you still can't provide a link? I'm beginning to get the impression that you don't really want help.
hi pauls, i apalogise for my poor english. i am not getting you many times. i think this is the link what you expect.
http://asynclabs.com/store?page=shop.product_details&product_id=26&vmcchk=1 :roll_eyes:
