Wich crystal can i use
this Crystal
can i use it with Atmega 328p ?
Sure, any normal crystal is okay.
If you buy a clone on AliExpress/Ebay/Amazon, then the crystal is much worse quality than the one that you have selected, and even those much worse crystals work.
The ATmega328P runs at 16MHz with 5V, and the crystal is only 8MHz.
There are also resonators, and the ATmega328P has an internal oscillator.
There are 22pF capacitors around the crystal, but some crystals prefer a lower value.
Don't start three topics that are basically the same.
i made a simple Schematic, that startet just when one of two signal come .
the signal turn on the N-Mosfet . signal come from other Arduino chip .
after the circuit startet ,it will sending the information with LoRa
can someone check my Design Please ?
i will programming it with FTDI .
i will using this Crystal 8 MHZ
the Bat give me 3 V
c4 c5 100nF
c2 c3 22pF
If you are proposing to operate with no crystal or ceramic resonator, then using a serial interface may not work so well.
The two main problems here are
  1. Re-inventing the wheel. If you want a 3.3 V "Arduino", an 8 MHz Pro Mini clone is inexpensive and easier/ cheaper than building your own.
  2. The Pro Mini does not include the USB interface. You use a separate adapter to program it. the point is, you do not use battery power and connect by USB, so you want to decide for one or the other. If it will connect to USB, you use a Nano (clone), if batteries, then a 3.3 V Pro Mini.
Your two topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Thank you.
Often a larger capacitor is added to VCC and GND.
The /RESET is missing a diode to VCC, the firmware might get corrupted when the /RESET pin turns into High Voltage mode by the DTR signal.
A inductor to AVCC also needs a capacitor of 100nF at AVCC.
A led with 330Ω is good, but its brightness depends a lot on the color of the led (forward voltage drop depends on color).
A RX pin that floats might cause interrupts because the ATmega328P might see start bits. You can add a resistor of 10k from RX to VCC. It is idle high.
I'm not sure about the low-side switching of the battery.
is the contact with LoRa RA-02 True ?
