I have created a Thing.
Added a variable called limitSwitch1 as read only bool on change.
Then created a dashboard and added the Status widget.
Added this into my code in the main loop.
limitSwitch1 = digitalRead(A0);
if(A0 == LOW){limitSwitch1 = false;}
else if(A0 == HIGH) {limitSwitch1 = true;}
I can click on the status widget in the dashboard, which changes its state but I want the state to change when the limit switch is pressed.
I get nothing happening with the dash widget when the limit switch is pressed.
This is my code.
#include "thingProperties.h"
#include <Wire.h>
#include <DS3232RTC.h>
#include <SolarPosition.h>
DS3232RTC myRTC;
#define MOTOR_ON LOW
#define MOTOR_OFF HIGH
const uint8_t digits = 3;
SolarPosition Home(15.898551, 101.539774); // Thailand
//SolarPosition Home(52.898551, -2.539774); // Home//RTC CODE
const int azEncoder_a = 2; // Green - pin 2 - Digital
const int azEncoder_b = 4; // White - pin 4 - Digital
long azEncoder = 0;
const int elEncoder_a = 3; // Green - pin 3 - Digital
const int elEncoder_b = 5; // White - pin 5 - Digital
long elEncoder = 0;
const int azLimitSwitchPin = A0; // DEFINE PIN TO USE FOR AZIMUTH LIMIT SWITCH
const int elLimitSwitchPin = A1; // DEFINE PIN TO USE FOR AZIMUTH LIMIT SWITCH
const int azMotorPinPositive = 9;
const int azMotorPinNegative = 8;
const int elMotorPinPositive = 7;
const int elMotorPinNegative = 6;
bool nightime;
bool daytime;
bool trackerAzimuthRunning = false;
bool trackerElevationRunning = false;
bool sunRising = false;
int azLimitSwitch; // VARIABLE TO HOLD THE ABOVE VALUE
int elLimitSwitch;
int hours;
int minutes;
int seconds;
int trackerAzimuthAngle;
int trackerElevationAngle;
int start = 0;
int azimuthSun_position;
float sunElevation;
float newPosition;
float oldPosition;
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
Wire.begin();
pinMode(azEncoder_a, INPUT_PULLUP);
pinMode(azEncoder_b, INPUT_PULLUP);
pinMode(elEncoder_a, INPUT_PULLUP);
pinMode(elEncoder_b, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), azEncoderPinChangeA, RISING);
attachInterrupt(digitalPinToInterrupt(3), elEncoderPinChangeB, RISING);
pinMode(azLimitSwitchPin, INPUT); // LIMIT SWITCH
pinMode(elLimitSwitchPin, INPUT); // LIMIT SWITCH
pinMode(azMotorPinPositive, OUTPUT);
pinMode(azMotorPinNegative, OUTPUT);
pinMode(elMotorPinPositive, OUTPUT);
pinMode(elMotorPinNegative, OUTPUT);
SolarPosition::setTimeProvider(myRTC.get);
ArduinoCloud.update();
rtcCode();
trackerAzimuthAngle = azEncoder / 1.67; //This change to degrees
trackerElevationAngle = elEncoder / 1.67; // 6This changes to degrees
azLimitSwitch = digitalRead(azLimitSwitchPin);
elLimitSwitch = digitalRead(elLimitSwitchPin);
if (newPosition > oldPosition) {
Serial.print("THE SUN IS GOING UP");
Serial.print('\n');
sunRising = true;
else if (newPosition < oldPosition) {
Serial.print("THE SUN IS GOING DOWN");
Serial.print('\n');
sunRising = false;
oldPosition = newPosition;
newPosition = sunElevation;
Serial.print("AZIMUTH LIMIT SWITCH STATUS =....."); //0 = Closed
Serial.print(azLimitSwitch);
Serial.print('\n');
Serial.print("ELEVATION LIMIT SWITCH STATUS =....."); // 0 = Closed
Serial.print(elLimitSwitch);
Serial.print('\n');
if (start < 1) {
homing(); // This statement checks to see if the programs has just started.
Serial.print("TRACKER AZIMUTH ANGLE IS ");
Serial.print(trackerAzimuthAngle);
Serial.print('\n');
Serial.print("TRACKER ELEVATION ANGLE IS ");
Serial.print(trackerElevationAngle);
Serial.print('\n');
//ADJUST THESE TIMES FOR TESTING
if (hours >= 4 && hours <= 21 && minutes <= 59 && seconds <= 59) {
daytime = true;
nightime = false;
nightime = true;
daytime = false;
Serial.print("DAYTIME ");
Serial.print(daytime);
Serial.print('\n');
Serial.print("NIGHTIME ");
Serial.print(nightime);
Serial.print('\n');
// CHANGE THE BELOW FOR TESTING
if (daytime == true) {
azimuthRunning();
Serial.print("PAUSED NOT MOVING UNTIL 6AM");
Serial.print('\n');
Serial.print('\n');
digitalWrite(azMotorPinPositive, HIGH);
// CHECK TO SEE IF ITS TIME TO HOME POSITIONE
if (hours == 17 && minutes == 47 && seconds == 0) {
homing();
void homing() {
digitalWrite(azMotorPinNegative, MOTOR_OFF);
digitalWrite(azMotorPinPositive, MOTOR_OFF);
digitalWrite(elMotorPinNegative, MOTOR_OFF);
digitalWrite(elMotorPinPositive, MOTOR_OFF);
//HOMING AZIMUTH
while (digitalRead(azLimitSwitchPin) == LOW) {
Serial.print("HOMING AZIMUTH");
Serial.print('\n');
digitalWrite(azMotorPinNegative, MOTOR_ON);
while (digitalRead(azLimitSwitchPin) == HIGH) {
Serial.print("BACKING OFF AZIMUTH"); //Change this to move motor
Serial.print('\n');
digitalWrite(azMotorPinPositive, MOTOR_ON);
azEncoder = 0; // Sets the encoder back to 0 once homed
//HOMING ELEVATION
while (digitalRead(elLimitSwitchPin) == LOW) {
Serial.print("HOMING ELEVATION");
Serial.print('\n');
digitalWrite(elMotorPinNegative, MOTOR_ON);
while (digitalRead(elLimitSwitchPin) == HIGH) {
Serial.print("BACKING OFF ELEVATION"); //Change this to move motor
Serial.print('\n');
digitalWrite(elMotorPinPositive, MOTOR_ON);
elEncoder = 0; // Sets the encoder back to 0 once homed
start++;
void azimuthRunning() {
if (azimuthSun_position > trackerAzimuthAngle && daytime == true && trackerElevationRunning == false) {
trackerAzimuthRunning = true;
Serial.print("AZ RUNNING ");
Serial.print("AZ Waiting ");
Serial.print('\n');
if (trackerAzimuthRunning == false) {
elevationRunning(); //Elevation Running only gets called if azimuth is not running
Serial.print('\n');
Serial.print('\n');
Serial.print('\n');
void elevationRunning() {
if (sunRising == true) {
elevationUp();
} else if (sunRising == false) {
elevationDown();
void elevationUp() {
if (sunElevation > trackerElevationAngle && daytime == true) {
trackerElevationRunning = true;
Serial.print("EL RUNNING GOING UP ");
else {
Serial.print("EL WAITING");
Serial.print('\n');
void elevationDown() {
if (sunElevation < trackerElevationAngle && daytime == true) {
Serial.print("EL RUNNING GOING DOWN ");
else {
Serial.print("EL GOING DOWN WAITING");
Serial.print('\n');
void rtcCode() {
printTime(myRTC.get());
Serial.print(F("Home:\t"));
printSolarPosition(Home.getSolarPosition(), digits);
void azEncoderPinChangeA() {
azEncoder += digitalRead(azEncoder_a) == digitalRead(azEncoder_b) ? -1 : 1;
void elEncoderPinChangeB() {
elEncoder += digitalRead(elEncoder_a) == digitalRead(elEncoder_b) ? 1 : -1;
void printSolarPosition(SolarPosition_t pos, int numDigits) {
Serial.print(F("el: "));
Serial.print(pos.elevation, numDigits);
Serial.print(F(" deg\t"));
Serial.print(F("az: "));
Serial.print(pos.azimuth, numDigits);
Serial.println(F(" deg"));
azimuthSun_position = (pos.azimuth);
sunElevation = (pos.elevation);
void printTime(time_t t) {
tmElements_t someTime;
breakTime(t, someTime);
Serial.print(someTime.Hour);
Serial.print(F(":"));
Serial.print(someTime.Minute);
Serial.print(someTime.Second);
Serial.print(F(" UTC on "));
Serial.print(dayStr(someTime.Wday));
Serial.print(F(", "));
Serial.print(monthStr(someTime.Month));
Serial.print(F(" "));
Serial.print(someTime.Day);
Serial.println(tmYearToCalendar(someTime.Year));
hours = someTime.Hour;
minutes = someTime.Minute;
seconds = someTime.Second;
