Widows 8 driver installation failure Code 28
I have downloaded the Arduino program and unzipped the software. But I cannot instal the driver, has anyone come across this problem and found a solution?
Steve
There was a post earlier today, described Win8 as wanting a 64 bit driver, Compaq modem was selected and worked. Search forum for "compaq modem" with today's date.
yes that works but you cant have the power cable in otherwise it will say its not functioning
properly
Hi all,
I have just managed it after a tip from an other forum. The short answer is too set your system time to ~ 01 Dec 2013 before attempting to update driver in the Device manager. Just brows to your unzipped folders Drivers and it should work. Remember to reset the system time after install.
Cheers
