I have received the UHF RFID Reader. I am having a slight problem reading the Tag ID. If I use the demo program I am able to read the Tag ID which is a typical EPC 96 bit code.
Do you at least get results that are self-consistent and unique to each tag? Is that not sufficient?
If not, you could always post a pile of matching EPC and Wiegand results and maybe someone will be able to figure out what algorithm they are using to reduce 96 bits of data to 24.
Thanks for the reply. I do get self consistent results which are unique to each tag. I suppose I'm simply curious as to how the Wiegand code is arrived at. In addition, if I'm able to source tags with their EPC printed on them, understanding how this is arrived out will allow me to confirm the Tag ID.
