I would say that I am an experienced programmer, not an experienced microcontroller programmer though. I got a wierd bug in a simple program that I cannot quite figure out. I hope that you guys can help me understand it. First of all the following code snippet (taken straight from Arduino's delay-function reference page - with a little adaption):
int ledPin = 13; // LED connected to digital pin 13
// #define ledPin 13 // If using this line instead of the one above, problems occur
pinMode(ledPin, OUTPUT); // sets the digital pin as output
digitalWrite(ledPin, HIGH); // sets the LED on
delay(1000); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
I got an Arduino UNO lying in front of me and an Arduino Mega 2560. When I upload that program in its original configuration I got my flashing test led on pin 13 - not problem on both boards. However, if I use the now uncommented #define-line instead of the int-variable for ledPin, I get no flashing Led what-so-ever on the Arduino UNO board. On the Mega 2560 board everything works just fine!
I know that both boards have different specifications/capabilities but the only thing I can think of is a memory problem (too little memory for only three times 13? I don't assume that this is the problem...) or a bug in the runtime libraries.
I also made a test setup to test different pins (currently only tested pin 1) and I get the same results. Wierd enough the problem does not occur if I am using ledPin as variable anywhere in pinMode or digitalWrite at least once:
// The following code works:
int ledPin = 13;
pinMode(13, OUTPUT); // <-- here
digitalWrite(13, HIGH); // <-- here
digitalWrite(13, LOW); // <-- or here, but once is enough
This is so wierd that I simply do not know what the reason for this problem is. Does anyone know what the problem is?
Just got the same idea... Fireing up my Ubuntu machine now.
I programmed my Arduino using Arch Linux with the current packages that were availabe using pacman. Now I will try it under Ubuntu 10.11. will post my results in here.
Might be time to break out Nick Gammon's char foo; solution
declare a useless variable at the very top of the program. Sometimes the IDE mangles translating your sketch into a compilable program.
Okay guys... I tested everything a bit more with help of my Ubuntu machine. My suspicion it is a compiler-problem:
Programs created and uploaded by my Ubuntu System work fine, but the ones from my Arch Linux installation do not. The compiler versions are:
Arch Linux (32bit):
avr-c++ (GCC) 4.6.2
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Ubuntu (64bit):
avr-g++ (GCC) 4.5.3
Copyright (C) 2010 Free Software Foundation, Inc.
The binary file sizes differ and well... I think I should try to upload the binary of one machine with the other just to be sure that it are the binaries. I used for my tests the same versions of the IDE on both machines - downloaded them both within the last 3 hours.
