wierd LED behaviour
I have one wierd LED behaviour. On machine I have few buttons and when one is pressed it should lite a LED and set motor speed.
Thing is that I am using A0-A3 pins and when I cycle trought them every one Works, but when I add it to program it doesn't. It won't even lite it in the loop loop.
I don't understand why since it is working when I make new blank program with just blink LED.
My whole program is here:
const int dirPin = 7;
const int stepperPin = 8;
const int homepolozaj = 2;
const int brzina1 = 3;
const int brzina2 = 4;
const int brzina3 = 5;
const int gore = 13;
const int dole = 6;
const int ms1 = 11;
const int ms2 = 10;
const int ms3 = 9;
byte stanje;
long brzina=100;
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  pinMode(A2, OUTPUT);
  pinMode(A3, OUTPUT);
  pinMode(ms1, OUTPUT);
  pinMode(ms2, OUTPUT);
  pinMode(ms3, OUTPUT);
  pinMode(dirPin, OUTPUT); //smjer6
  pinMode(stepperPin, OUTPUT);
  pinMode(homepolozaj, INPUT); // limitswitch - pin 2
  digitalWrite(homepolozaj, HIGH); // pali interni pullup
  pinMode(brzina1, INPUT); // prva brzina - pin 3
  digitalWrite(brzina1, HIGH); // pali interni pullup
  pinMode(brzina2, INPUT); // druga brzina - pin 4
  digitalWrite(brzina2, HIGH); // pali interni pullup
  pinMode(brzina3, INPUT); // treca brzina - pin 5
  digitalWrite(brzina3, HIGH); // pali interni pullup
  pinMode(gore, INPUT); // start - pin 2
  digitalWrite(gore, HIGH); // pali interni pullup
  pinMode(dole, INPUT); // start - pin 2
  digitalWrite(dole, HIGH); // pali interni pullup
  pocetak();
   tipkovnica();
void pocetak () {
  digitalWrite(dirPin, LOW  );
  stanje = digitalRead(homepolozaj);
  while (stanje == HIGH)
    digitalWrite(stepperPin, HIGH);
    delayMicroseconds(1000);
    digitalWrite(stepperPin, LOW);
void tipkovnica () {
  if (digitalRead(brzina1) == LOW)
    brzina=36999;
    digitalWrite(ms1, LOW);
    digitalWrite(ms2, HIGH);
    digitalWrite(ms3, LOW);
    digitalWrite(A0, HIGH);
    digitalWrite(A1, LOW);
    digitalWrite(A2, LOW);
  else if (digitalRead(brzina2) == LOW)
    brzina=1000;
    digitalWrite(A0, LOW);
    digitalWrite(A1, HIGH);
  else if (digitalRead(brzina3) == LOW)
    brzina=10000;
    digitalWrite(A2, HIGH);
  else if (digitalRead(dole) == LOW)
  digitalWrite(dirPin, HIGH );
    digitalWrite(A3, HIGH);
    delayMicroseconds(brzina);
 // digitalWrite(radiled, HIGH);
Which one should? Which pin is the LED connected to?
Buttons are pins 3 (brzina1); 4 (brzina2) and 5 (brzina3) and leds are A0, A1 and A2
What do your Serial.print() statements tell you is happening? Are the switches being read properly?
How do you mean serial.print() since I don't use it in program
chuspy:
Psst, I think that was a hint that you should.
I could be wrong.
I often am.
chuspy:
Did you mean "weird" or "wired"?
