Wierd problems with serial communication
first of all: hello everyone. i am new here. :slight_smile:
i’m from germany, so i hope everyone can understand what i’m typing and help me. :smiley:
okay, here is my problem: i’m using the arduino mega 2560 and over the serial ports i want to communicate with a rfid-reader.
communication works fine with the old reader i have. it sends 12 bytes with 9600 baud and 8 data bits, no parity and one stop bit.
i can read those bytes and i can send them to my pc. it shows me all the all bytes send and they are the same ones i can see on my oscilloscope.
additionally i count the number of bytes that is send and send that number to a lcd-display.
and like it should it tells me 12.
so, now i got a new rfid reader.
this one communicates with 9600 baud and 8 data bits, even parity and one stop bit.
so i configured my serial port new with: Serial3.begin(9600, SERIAL_8E1);
this reader does send me 11 bytes. i see those bytes on my oscilloscope.
but i dont see them on my PC. sometimes i get the right bytes, but most of the time i only get 0B.
and when i check the number of bytes send like befor it tells me 256, or even higher numbers.
sometimes i see the 11, but most of the time it tells me a higher number.
what could be the problem?
the configuration of the serial port is done right.
i can send commandes to the reader and it understands me.
the bytes are being send all 50ms. is that to fast?
what could i do about that?
btw.: how does the serial buffer work in the first place?
how does it know that i am waiting for 11, or 12 bytes?
i use the same code for both readers. for the second one i just change it to even parity.
#include <LiquidCrystal.h>
LiquidCrystal lcd(9, 8, 5, 4, 3, 2);
int come_in [12];
char test_speicher [12];
int x = 0;
int z=0;
const int reset   = 40;           // Pin-Nummer Reset-Pin des RFID-Moduls
  lcd.begin(20, 4);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print ("Hallo");
  Serial3.begin(9600, SERIAL_8E1);    //9600 baud, 8 data bits, even parity, 1 stop bit
  digitalWrite(reset,HIGH);
  lcd.clear();
if (Serial3.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // read all the available characters
    while (Serial3.available() > 0) {
      come_in[ z ] = Serial3.read();
      z++;
    for( int i=0; i<z; i++ ){
      test_speicher[ i ] = come_in[ i ];
    Serial.print(test_speicher);
  lcd.setCursor(0, 1);
  lcd.print( z );
oh and an other quick question: I am using the the first serial port “Serial” too and everytime i want to program the board over usb, i have to disconnect the pins 0 and 1.
is that the only way to program the board?
hope u understood my problem and can maybe help me.
btw.: feel free to correct my english. ^^
You have to disconnect the serial port used by usb-to-serial for the Arduino IDE.
But you can make more serial ports with SoftwareSerial.
Perhaps you can keep the first serial port for the Arduino IDE.
If you use a oscilloscope, can you measure and calculate the baudrate and the voltage level ? If the voltage level is only 3V and the baudrate is 10% off, that could be a problem.
You don’t check for the maximum buffer size while characters are being received. So it will be very easy to get ram overflow.
while (Serial3.available() > 0 && z < sizeof( come_in))
You have to disconnect the serial port used by usb-to-serial for the Arduino IDE. But you can make more serial ports with SoftwareSerial. Perhaps you can keep the first serial port for the Arduino IDE.
In order: No. usb-to-serial is on Serial, not Serial3. Not necessary. There are 4 hardware serial ports on the Mega. The OP already is using Serial (separate port) for the IDE.
i am also using Serial for sending the data read from Serial3.
and isnt the maximum buffer size 64?
okay, i made some progress with the help of a colleague.
so you dont have to read the first post:
i am using this now:
void loop(){
  lcd.print ("Loop");
    Serial3.setTimeout(50);
    Serial3.readBytes(come_in,11);
    for( int i=5; i<10; i++ ){                       // I get 11 bytes, but only need the information
      test_speicher[ i-5 ] = come_in[ i ];      // in the bytes 6 to 10
    test_speicher[5] = 0;
    Serial2.print((char*)test_speicher);
test_speicher is a char array with the size of 6.
so this works quite good.
but i have a few things that bother me.
1st: even if i hold the transponder into the antenna for only a short moment i already get 5 serial prints to my PC.
2nd: if i let the transponder stay in the antenna field, after a short time, i get wrong numbers.
