Wierd symbols in the Serial Monitor
I am using an ESP32 with the WiFi library with a ntp server. I am using the ntp server time for a clock wich I built. I have also tried it with an Arduino Nano without Wifi and a RTC and this functions. I would like to print the time in the Serial Monitor but I only get weird symbols like this " a� �+)� �$K����� DhOW�q,[�V3��3�B��Y�`�bb@���� ;�aW ��W(�N
H��m@��]���B,�Q�0�/�������yh8��8����,�SVd���X�P�.�ـ�@ V$%��L��a�����0�N�H��6 a� �+)��)-�A� X�Z��0)� A$K2 �a���\��! �Ke ������\ bb� ��L.�������6���H��6�� D4O� b�$K�����aM�����!X��� �B�zY��n� ����$�� @�(yĨ6]���a�,� @8H�(3A.^0Qs � �T��I�<�� !�']Ƞ�)�.�8A�/��'�Ƞ��1�e,p�(� ,�zy���� �BX���������\ �V3� �r� DdOW%��@� K����� �4���9)-� �G����lc�®�,�$���L���r��RW�#�z��
`f��]�A�!�Y�� qJ� ���R�zy�0��NbH��.� � ,�~�". But I do not know why.
This happens when you have not set the baud rate in the serial monitor to the same baud rate you are feeding the signal to the serial monitor.
As @Grumpy_Mike said, most likely the baud rate is wrong - see:
Serial Communication - SparkFun Learn.
I have the same baud rate in the Serial Monitor
Are you 100% sure of that?
IIf so it could mean your Arduino is broken.
or maybe running at the wrong clock speed?
Do you see that only at boot time? The ESP32 may print debug information at that time, if your sketch/monitor is set for a different baud rate, the debug message will look like that...
What baud rates are you using?
I am using 9600.
You answered only one of two questions.
