Wifi 101 webserver with SD card
I am trying to use the Wifi101 library to set up a webserver to load a page from an SD card.
The problem is I can load the webpage once but when I try to reload it doesn't work.
Parts:
Adafruit ATWINC1500
Adafruit microSD breakout
Library:
a fork of the Wifi101 library that allows pin changes
Code:
Based off of WifiWebServer example
My hunch is it has something to do with the TCP connection. In wireshark I saw that the second TCP connection is setup and the browser sends the HTTP request and the server ACKs it. And then nothing.
If I just run the WifiWebServer it works but with the SD card it doesn't?
Any ideas?
  WiFi Web Server
 A simple web server that shows the value of the analog input pins.
 using a WiFi shield.
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the Wifi.begin() call accordingly.
 Circuit:
 * WiFi shield attached
 * Analog inputs attached to pins A0 through A5 (optional)
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 31 May 2012
 by Tom Igoe
#include <SPI.h>
#include <Adafruit_WINC1500.h>
#include <SD.h>
// Define the WINC1500 board connections below.
// If you're following the Adafruit WINC1500 board
// guide you don't need to modify these:
#define WINC_CS   8
#define WINC_IRQ  7
#define WINC_RST  4
// #define WINC_EN   2     // or, tie EN to VCC and comment this out
// The SPI pins of the WINC1500 (SCK, MOSI, MISO) should be
// connected to the hardware SPI port of the Arduino.
// On an Uno or compatible these are SCK = #13, MISO = #12, MOSI = #11.
// On an Arduino Zero use the 6-pin ICSP header, see:
//   https://www.arduino.cc/en/Reference/SPI
//SD chip select pin
#define SD_CS 10
// Setup the WINC1500 connection with the pins above and the default hardware SPI.
Adafruit_WINC1500 WiFi(WINC_CS, WINC_IRQ, WINC_RST);
// Or just use hardware SPI (SCK/MOSI/MISO) and defaults, SS -> #10, INT -> #7, RST -> #5, EN -> 3-5V
//Adafruit_WINC1500 WiFi;
char ssid[] = "ssid";      // your network SSID (name)
char pass[] = "passs";   // your network password
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
Adafruit_WINC1500Server server(80);
//sd class instance
File myFile;
#ifdef WINC_EN
  pinMode(WINC_EN, OUTPUT);
  digitalWrite(WINC_EN, HIGH);
#endif
pinMode(WINC_CS, OUTPUT);
pinMode(SD_CS, OUTPUT);
digitalWrite(WINC_CS, HIGH);
digitalWrite(SD_CS, HIGH);
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
  // turn off wifi shield
  //active LOW
  Serial.print("Initializing SD card...");
//init of SD and spi
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  //SD is a global object
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  //unselect sd card
 // turn onwifi shield
 // digitalWrite(WINC_CS, LOW);
  // listen for incoming clients
  Adafruit_WINC1500Client client = server.available();
  //big loop
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
//      Serial.println("c");
      if (client.available()) {
//        Serial.println("a");
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
//          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println();
          //print the front webpage
          webPageFromSD(client, "list.htm");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
//open web page from a file on the SD card
//param: the Adafruit_WINC1500Client
//param: the name of the file on the SD card
//return: void
void webPageFromSD(Adafruit_WINC1500Client client, String name)
  myFile = SD.open(name);
  if (myFile) {
    Serial.println(name);
      //do the access to SPI line separately, first read from SD card
//      delay(1);
      char j = myFile.read();
      //then print it to client using Wifi on the SPI
//      delay(1);
      client.print(j);
    // close the file:
//    myFile.close();
    Serial.println("sd error opening");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
your problem is with client.print(j); in the
where did you even declare client? If you delcare an int in void loop() section, do you expect the int to be valid in webPageFromSD() section? Wont work.
Instead, try to return a string and then print that string in client.print(returnedString);
I presume you are using a shield which requires the Adafruit library rather than the Arduino WiFi 101 library?
I have the arduino card and library so it is difficult to make statements with 100% certainty of success. However, some observations:
Turn on line numbering in File preferences, display line Numbers
At line 67 / 68 DigitalWrite, WINC_CS and SD_CS LOW-
Leave the lines low- this works for me
As long as you initialise the filing system before the wifi card
At line 146 you de-select the sdcard and never re-select it
At line 101 you deselect the wifi card and never reselect it
Move the connection. close line at 175 above line 174 and remove comments
At line 179 - you pass the client as a subroutine parameter- that's fine.
At line 179 does list.htm exist- you created a text file called test.txt at line 115?
Line 207 receives the client variable into a local variable called client- that's fine too
At line 224 myFile should close
