I'm going to look into it a little further. I have a few ideas that I want to look into, for example, if I know I'll always use wifi as an access point I can take out a few lines having to do with connecting.
Right now I get:
[ 0.000000] Linux version 3.3.8 (jenkins@jenkins) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Jun 20 12:50:18 CEST 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00004000
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat 803836d0, node_mem_map 81000000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 16256 pages, LIFO batch:3
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=Yun console=ttyATH0,250000 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,14656k(rootfs),1280k(kernel),64k(nvram),64k(art),15936k@0x50000(firmware) rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 60936k/65536k available (2565k kernel code, 4600k reserved, 650k data, 180k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.090000] MIPS: machine is Arduino Yun
[ 0.530000] Setting DogStick2 GPIO
[ 0.550000] bio: create slab <bio-0> at 0
[ 0.550000] SCSI subsystem initialized
[ 0.560000] usbcore: registered new interface driver usbfs
[ 0.560000] usbcore: registered new interface driver hub
[ 0.560000] usbcore: registered new device driver usb
[ 0.570000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.580000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.580000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.580000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.580000] TCP reno registered
[ 0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] NET: Registered protocol family 1
[ 0.610000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.610000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.620000] msgmni has been set to 119
[ 0.620000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.620000] io scheduler noop registered
[ 0.630000] io scheduler deadline registered (default)
[ 0.630000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.640000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[ 0.640000] console [ttyATH0] enabled, bootconsole disabled
[ 0.650000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.650000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.650000] 7 cmdlinepart partitions found on MTD device spi0.0
[ 0.660000] Creating 7 MTD partitions on "spi0.0":
[ 0.660000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.660000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.670000] 0x000000050000-0x000000ea0000 : "rootfs"
[ 0.670000] mtd: partition "rootfs" set to be root filesystem
[ 0.670000] mtd: partition "rootfs_data" created automatically, ofs=7A0000, len=700000
[ 0.680000] 0x0000007a0000-0x000000ea0000 : "rootfs_data"
[ 0.680000] 0x000000ea0000-0x000000fe0000 : "kernel"
[ 0.680000] 0x000000fe0000-0x000000ff0000 : "nvram"
[ 0.690000] 0x000000ff0000-0x000001000000 : "art"
[ 0.690000] 0x000000050000-0x000000fe0000 : "firmware"
[ 0.710000] ag71xx_mdio: probed
[ 0.720000] eth0: Atheros AG71xx at 0xba000000, irq 5
[ 1.270000] eth0: Found an AR7240/AR9330 built-in switch
[ 2.300000] eth1: Atheros AG71xx at 0xb9000000, irq 4
[ 2.850000] ag71xx ag71xx.0: eth1: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 2.850000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.850000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[ 2.860000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 2.890000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 2.910000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 2.910000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.910000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.910000] usb usb1: Product: Generic Platform EHCI Controller
[ 2.920000] usb usb1: Manufacturer: Linux 3.3.8 ehci_hcd
[ 2.920000] usb usb1: SerialNumber: ehci-platform
[ 2.920000] hub 1-0:1.0: USB hub found
[ 2.920000] hub 1-0:1.0: 1 port detected
[ 2.930000] Initializing USB Mass Storage driver...
[ 2.930000] usbcore: registered new interface driver usb-storage
[ 2.930000] USB Mass Storage support registered.
[ 2.930000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 2.940000] sdhci: Secure Digital Host Controller Interface driver
[ 2.940000] sdhci: Copyright(c) Pierre Ossman
[ 2.940000] usbcore: registered new interface driver ushc
[ 2.940000] TCP cubic registered
[ 2.950000] NET: Registered protocol family 17
[ 2.950000] Bridge firewalling registered
[ 2.950000] 8021q: 802.1Q VLAN Support v1.8
[ 2.960000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 2.960000] Freeing unused kernel memory: 180k freed
[ 3.250000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 3.460000] usb 1-1: New USB device found, idVendor=058f, idProduct=6254
[ 3.460000] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.470000] usb 1-1: Product: USB2.0Hub
[ 3.550000] hub 1-1:1.0: USB hub found
[ 3.550000] hub 1-1:1.0: 4 ports detected
[ 3.830000] usb 1-1.4: new high-speed USB device number 3 using ehci-platform
[ 4.040000] usb 1-1.4: New USB device found, idVendor=058f, idProduct=6366
[ 4.040000] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.040000] usb 1-1.4: Product: Mass Storage Device
[ 4.050000] usb 1-1.4: Manufacturer: Generic
[ 4.050000] usb 1-1.4: SerialNumber: 058F0O1111B1
[ 4.060000] scsi0 : usb-storage 1-1.4:1.0
[ 5.040000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 5.060000] scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
[ 6.270000] Registered led device: ds:green:usb
[ 6.270000] Registered led device: ds:green:wlan
[ 9.610000] JFFS2 notice: (526) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 16 of xref (0 dead, 5 orphan) found.
[ 10.790000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 38.060000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 38.070000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 39.680000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 39.730000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 39.860000] PPP generic driver version 2.4.2
[ 39.910000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 40.030000] NET: Registered protocol family 24
[ 40.070000] nf_conntrack version 0.5.0 (954 buckets, 3816 max)
[ 40.510000] i2c /dev entries driver
[ 40.550000] Linux video capture interface: v2.00
[ 40.730000] fuse init (API version 7.18)
[ 40.800000] usbcore: registered new interface driver uvcvideo
[ 40.800000] USB Video Class driver (1.1.1)
from dmesg and I'm trying to figure out what/why there is that ~28 second delay (I'm not using an SD at the moment) after the:
