Hi, I currently use a WiFi adapter with a yun rev2. Because the one, on board dont have a good signal force for our appliance, we use one usb adaptee in 2.4 ghz . Yun is running with os openwrt. I want to know what adapter I could use for upgrade to 5g. We don't want if possible to change the openwrt os. Have solution, wifi adapter , etc. ?
5g isn't WiFi. What exactly are you trying to achieve? The built-in WiFi uses 2.4GHz frequencies. I understand that you need something else but I have no clue what you really need.
there are wifi in 2.4G, now have too in 5G
That's called 2.4GHz and 5GHz! 5G is commonly used to refer to the new mobile standard.
Unfortunately I don't know any USB WiFi adapter supported by OpenWRT that has a WiFi transceiver that uses the 5GHz frequency range.
