WiFi AP mode example refuses connection
I am having problems with the following code from:
# Wi-Fi AP Mode Example
# This example shows how to use Wi-Fi in Access Point mode.
import network, socket, sys, time, gc
SSID ='My_Nano_RP2040_Connect'   # Network SSID
KEY  ='1234567890'  # Network key (must be 10 chars)
HOST = ''           # Use first available interface
PORT = 8080         # Arbitrary non-privileged port
# Init wlan module and connect to network
wlan = network.WLAN(network.AP_IF)
wlan.active(True)
wlan.config(ssid=SSID, key=KEY, security=wlan.WEP, channel=2)
print("AP mode started. SSID: {} IP: {}".format(SSID, wlan.ifconfig()[0]))
def recvall(sock, n):
    # Helper function to recv n bytes or return None if EOF is hit
    data = bytearray()
    while len(data) < n:
        packet = sock.recv(n - len(data))
        if not packet:
            raise OSError("Timeout")
        data.extend(packet)
    return data
def start_streaming(server):
    print ('Waiting for connections..')
    client, addr = server.accept()
    # set client socket timeout to 5s
    client.settimeout(10.0)
    print ('Connected to ' + addr[0] + ':' + str(addr[1]))
    # FPS clock
    clock = time.clock()
    while (True):
        try:
            # Read data from client
            data = recvall(client, 1024)
            # Send it back
            client.send(data)
        except OSError as e:
            print("start_streaming(): socket error: ", e)
            client.close()
            break
while (True):
    try:
        server = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        # Bind and listen
        server.bind([HOST, PORT])
        server.listen(1)
        # Set server socket to blocking
        server.setblocking(True)
        while (True):
        server.close()
        print("Server socket error: ", e)
When I run the above code I get an IP Address and a message that says "Waiting for connections".
"AP mode started. SSID: My_Nano_RP2040_Connect IP: 192.168.4.1
Waiting for connections.."
When I try to connect to the IP address I get a connection refused message from the laptop (Windows 10/ Google Chrome).
After removing some redundant code that was causing errors and temporarily disabling timeouts, I can now Telnet to the RP2040 Connect. The modified code and results follows:
 #Wi-Fi AP Mode Example
wlan.active(True)
    data = bytearray()
        print ("Packet",packet)
        if not packet:
        data.extend(packet)
    return data
    # set client socket timeout to 30s
    # Comment this out for no timeouts
    #client.settimeout(30.0)
    while (True):
        try:
            # Send it back
            client.send(data)
            client.close()
            break
while (True):
    try:
        # Bind and listen
        server.listen(1)
        print("Listening")
        while (True):
        server.close()
        print("Server socket error: ", e)type or paste code here
Response:
Listening
Connected to 192.168.4.3:64772
Packet b"\xff\xfb\x1f\xff\xfb \xff\xfb\x18\xff\xfb'\xff\xfd\x01\xff\xfb\x03\xff\xfd\x03"
Packet b'Hello World'
Packet b'\r\n'
