I'm hoping someone here might be able to give me a hint on a WiFi solution that I can integrate with a Arduino compatible solution. Specifically, I'd like a WiFi module which has the following features:
- Soft/Limited AP mode (just needs to allow 1 client to connect)
- DHCP Server
- Ability to simultaneously listen on multiple TCP ports for connections and multiplex between them
So far #3 seems to be the hard part. The Roving Networks RN-171 does the first two, but only supports listening on a single port. I've also been looking at the WizNet WizFi210/220, but the spec sheet is very vague about this and the code examples in their GitHub repo don't indicate there is any way to tell which TCP port/socket you are receiving data from. I looked at the TI CC3000, but it doesn't support AP mode.
For those of you curious, it's for this project here: GitHub - synfinatic/teensy-dsc: Teensy code & PCB design for digital setting circles
Any suggestions? Thanks!
