WiFi AP won't start
Could anyone check why my AP server won’t start?
No firmware failure.
No WiFi device failure.
Internal led blinks like it should every second.
Thank you
#include <SPI.h>
#include <WiFiNINA.h> //Include this instead of WiFi101.h as needed
char ssid_server = “SunDatalogger”; // your network SSID (name)
char pass_server = “Aap”; // your network password (use for WPA, or use as key for WEP)
WiFiServer server(80);
int status = WL_IDLE_STATUS;
SPI.begin();
delay(5000);
Serial.println(“Starting”);
if (WiFi.status() == WL_NO_MODULE) {
Serial.println(“Communication with WiFi module failed!”);
// don’t continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println(“Please upgrade the firmware”);
WiFi.beginAP(ssid_server, pass_server);
if (status != WL_AP_LISTENING) {
Serial.println(“Creating access point failed”);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(LED_BUILTIN, HIGH);
WPA password must be at least 8 characters long usually.
Thanks, can give it a try. I now use this code. It is only use for asking a user for wifi credentials.
status=WiFi.beginAP(“TempNetwork”); // dit werkt
cntr=0;
while (cntr<10 and status!= WL_AP_LISTENING)
if (status == WL_AP_LISTENING) { break; }
else { status=WiFi.beginAP(“TempNetwork”); }
cntr=cntr+1;
delay(5000);
server.begin();
The AP simple webserver sketch under the WiFi Nina library works only when you set the password for atleast 8 characters.
