WIfi.begin() fails status=6, disconnected , on Nano iot, resolved
I have this sketch that creates an AP or connects to the access point depending on the config.
was built with 1.8.12
I am starting to add web server to this.. it complained on downlevel firmware, so I updated.
I also updated the IDE to 1.8.19 and the samd libs to 1.8.13..
build happens with 1.8.13..
Using board 'nano_33_iot' from platform in folder: /Users/sam/Library/Arduino15/packages/arduino/hardware/samd/1.8.13
Using core 'arduino' from platform in folder: /Users/sam/Library/Arduino15/packages/arduino/hardware/samd/1.8.13
Using library WiFiNINA at version 1.8.13 in folder: /Users/sam/Documents/Arduino/libraries/WiFiNINA
the sketch says the firmware is latest
 Wifi firmware version=1.4.8
// was at 1.4.5
but now my Wifi.begin(ssid) returns rc=6 Disconnected..
// the test network doesn't have a passcode set)
the AP side works ok..
So, I decided to connect to my local wifi.. (that DOES have a passcode)
that also fails rc=6..
I wait 10 seconds and try again.. never to succeed in either case.
this depends on a static variable.  bool MakeAP=true; or false.
#include <WiFiNINA.h> // this is 1.8.13
setup(){
if(MakeAp == true) {
// the ap side , this  works ok, can connect from desktop and laptop
 status= WiFi.beginAP(ssid); // try to make AP
      if (status != WL_AP_LISTENING) {
          some error message
the client system side
else {
        Serial.print("status=");
        Serial.println(WiFi.status());
        // wait 10 seconds
        delay(10000);
        WiFi.begin(ssid); // connect to the ap created by other Nano iot, no passcode
        // for debug only) connect to home wifi
        WiFi.begin(ssid1,passcode);  // test connect to home network , with passcode
I don't see any changes in the api in the Nina doc.
is there something else I can do for debug?
thanks
here is a sketch that demos the failure
change these lines (below) when type = Member to connect to a ;local access point
char ssid[]="network_ssid";
char passcode[]="network_passcode";
#include <SPI.h>
#define AccessPoint 1
#define Member 2
int type = Member;
     while (!Serial)
  if(type == AccessPoint){
      char ssid[]="network1";
      Serial.print("Attempting to create Network named: ");        // print the network name (SSID)
      Serial.println(ssid);
      int status= WiFi.beginAP(ssid); // try to connect
        Serial.println("Creating access point failed");
        // don't continue
        while (true);
        // wait 30 seconds
        delay(10000);
        Serial.print("Attempting to connect to Network named: ");        // print the network name (SSID)
        WiFi.begin(ssid,passcode);
        delay(2000);
Serial.println("setup completed");
if you use some non-existant SSID , then u get status=4, WL_CONNECT_FAILED, as expected
now, this local network is both 2g and 5g
results.. if u have a true 2.4g wifi network then the connect is ok..
