Hello,
I measure temperature, humidity, water and air quality with esp 32 d1 r32 card and I want it to send an e-mail depending on the situation. But Wifi begin(ssid,pass); Because of the code, the water level always goes up to 100. The sensor you are using is HW-038. Can you help with the subject?
#include "ESP32_MailClient.h"
#include "MQ135.h"
#include "DHT.h"
const char* ssid = "test";
const char* password = "test";
#define emailSenderAccount "sdf@sdfsf.com"
#define emailSenderPassword "dgfhdh"
#define emailRecipient "sdf.ghf@fgd.com"
#define smtpServer "smtp.office365.com"
#define smtpServerPort 587
#define emailSubject "IT ODASI UYARI"
#define DHTPIN 17
#define DHTTYPE DHT11
#define MQ135PIN 34
MQ135 mq135(MQ135PIN);
LiquidCrystal_I2C lcd(0x27, 16, 2);
DHT dht(DHTPIN, DHTTYPE);
SMTPData smtpData;
const int analogInPin = 14; // HW-038 sensörünü analog pine bağlayın
int sensorValue = 0; // sensör verisi
float voltage = 0; // sensör voltajı
float waterLevel = 0; // su seviyesi
float minVoltage = 0.20; // sensör minimum voltajı
float maxVoltage = 4.00; // sensör maksimum voltajı
void sendCallback(SendStatus info);
void setup(){
Serial.print("Connecting");
WiFi.begin(ssid, password);
Serial.print(".");
delay(200);
Serial.println("WiFi connected.");
Serial.println("Preparing to send email");
dht.begin();
lcd.begin();
lcd.backlight();
dht.begin();
lcd.setCursor(0, 0);
lcd.print("sdf sdf");
delay(8000);
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
int air_quality = mq135.getPPM();
sensorValue = analogRead(analogInPin); // analog pinden veri oku
voltage = sensorValue * (3.3 / 4095.0); // voltaj hesapla
if (voltage > minVoltage) { // minimum voltaj kontrolü
waterLevel = 100; // su seviyesi 0%
} else if (voltage < maxVoltage) { // maksimum voltaj kontrolü
waterLevel = 0; // su seviyesi 100%
waterLevel = 100 - (voltage - minVoltage) * 100 / (maxVoltage - minVoltage); // su seviyesi hesapla
lcd.clear();
lcd.print("Sicaklik: ");
lcd.print(temperature);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print("Nem: ");
lcd.print(humidity);
lcd.print("%");
delay(5000);
lcd.clear();
lcd.print("Hava:");
lcd.print(air_quality/1000);
lcd.print("ppm");
lcd.print("Su seviyesi: ");
lcd.print(waterLevel);
lcd.print("%");
delay(5000);
lcd.clear();
if(temperature > 27.0)
smtpData.setLogin(smtpServer, smtpServerPort, emailSenderAccount, emailSenderPassword);
smtpData.setSender("ESP32", emailSenderAccount);
smtpData.setPriority("High");
smtpData.setSubject(emailSubject);
smtpData.setMessage("<div><h1 style=\"color:red;\">Sıcaklık Uyarısı!</h1><p>Lokasyon:EKO ENDUSTRI IT ODASI</p><p>Sensör:Sıcaklık</p><p> Sıcaklık Değeri:23 °C Üzerinde </p></div>", true);
smtpData.addRecipient(emailRecipient);
smtpData.setSendCallback(sendCallback);
if (!MailClient.sendMail(smtpData))
Serial.println("Error sending Email, " + MailClient.smtpErrorReason());
smtpData.empty();
if(humidity > 65.0)
smtpData.setMessage("<div><h1 style=\"color:red;\">Nem Uyarısı!</h1><p>Lokasyon:EKO ENDUSTRI IT ODASI</p><p>Sensör:Nem</p><p>Nem Değeri:65(%RH) Değerinin Üzerinde</p></div>", true);
smtpData.empty();
if(air_quality/1000 > 2500.0)
smtpData.setMessage("<div><h1 style=\"color:red;\">Hava Kalite Uyarısı!</h1><p>Lokasyon:EKO ENDUSTRI IT ODASI</p><p>Sensör:Hava Kalitesi</p><p>Hava Kalitesi:4000 ppm Değerinin Üzerinde</p></div>", true);
smtpData.empty();
if(waterLevel < 99)
smtpData.setMessage("<div><h1 style=\"color:red;\">Su Seviyesi Uyarısı!</h1><p>Lokasyon:EKO ENDUSTRI IT ODASI</p><p>Sensör:Su</p><p>Su değeri:Belirlenen Seviyenin Üzerinde</p></div>", true);
smtpData.empty();
void sendCallback(SendStatus msg) {
Serial.println(msg.info());
lcd.print("C");
lcd.print("Nem: ");
lcd.print("%");
delay(5000);
lcd.clear();
lcd.print("Hava:");
lcd.print("ppm");
lcd.print("%");
delay(5000);
lcd.clear();
