I started programming some test code using the WiFi class using the method with this signature:
WiFi.begin(ssid, keyIndex, key);
It wouldn't compile, and I receive this error message:
Arduino: 1.6.5 (Windows 8.1), Board: "Adafruit HUZZAH ESP8266, 80 MHz, 115200, 4M (3M SPIFFS)"
Using library ESP8266WiFi in folder: C:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi
C:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0/tools/sdk/include -IC:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0/tools/sdk/lwip/include -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266 -IC:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\variants\adafruit -IC:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src C:\Users\Keith\AppData\Local\Temp\build6750996651168249027.tmp\ESP8266-WEPConnect.cpp -o C:\Users\Keith\AppData\Local\Temp\build6750996651168249027.tmp\ESP8266-WEPConnect.cpp.o
ESP8266-WEPConnect.ino: In function 'void setup()':
ESP8266-WEPConnect.ino:31:35: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'char*' [-fpermissive]
In file included from C:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:34:0,
from ESP8266-WEPConnect.ino:1:
C:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFiSTA.h:39:21: error: initializing argument 2 of 'wl_status_t ESP8266WiFiSTAClass::begin(char*, char*, int32_t, const uint8_t*, bool)' [-fpermissive]
wl_status_t begin(char* ssid, char passphrase = NULL, int32_t channel = 0, const uint8_t bssid = NULL, bool connect = true);
ESP8266-WEPConnect.ino:31:35: error: invalid conversion from 'const char*' to 'int32_t {aka int}' [-fpermissive]
C:\Users\Keith\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFiSTA.h:39:21: error: initializing argument 3 of 'wl_status_t ESP8266WiFiSTAClass::begin(char*, char*, int32_t, const uint8_t*, bool)' [-fpermissive]
It is obvious from the error that the method expects the SSId to be the second argument and the index to be the third. In fact when I switched them and recompiled, it worked fine.
I just thought you all would like to know so that the documentation can be updated.
