I want to remotely control a rover over a distance of about 40-50m (without internet) with Arduino. It seems that I could use something like a Hydrogen Wifi shield and turn the Arduino into an access point. I don't know how good the signal would be over 40 or so metres though. Would bluetooth be a good solution? How about xBee?
I'm using XBee on my Rover5 and getting a few hundred metres, from inside the house with only a 3dBi antenna.
Have a look at the video's I've posted here and on YouTube.
In the video where you can see me outside as the rover goes past, I drive out of "line of sight" and behind a pile of rubble then below the brow of a hill.
I'm using series 1 60mW XBee Pro modules, I'll be switching over to 900Mhz modules soon to stop interference with my analogue video link.
cyberteque:
I have a copy of "Making Things Talk" and "Programming Interactivity", there are lot's of examples in both books.
On the DIYDrones site, they talk about using XBee for telemetry.
When I first got into Arduino, second thing I bought was a pair of XBee modules, XBee shield and USB XBee Explorer in the Sparkfun retail kit.
My first experiments showed me was how easy it was to get 2 XBee's to talk, straight "out of the box".
Didn't even bother setting them up with X-CTU, it was like having a serial cable between 2 Arduino's.
After I got serious about monitoring temperature and humidity in the barns, I work on a turkey farm, I bought my Rover 5 and started messing around with it.
Took me all of an hour to get the code to work on the rover.
My transmitter sends exactly the same codes that I control the rover with from my keyboard.
