I don't working my sites ("yunuscanyuz.com/ardugelen.aspx" send request ![]()
This is an example for the Adafruit CC3000 Wifi Breakout & Shield
Designed specifically to work with the Adafruit WiFi products:
----> https://www.adafruit.com/products/1469
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried & Kevin Townsend for Adafruit Industries.
BSD license, all text above must be included in any redistribution
This example does a test of the TCP client capability:
* Initialization
* Optional: SSID scan
* AP connection
* DHCP printout
* DNS lookup
* Optional: Ping
* Connect to website and print out webpage contents
* Disconnect
SmartConfig is still beta and kind of works but is not fully vetted!
It might not work on all networks!
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID "***" // cannot be longer than 32 characters!
#define WLAN_PASS "***"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS 3000 // Amount of time to wait (in milliseconds) with no data
// received before closing the connection. If you know the server
// you're accessing is quick to respond, you can reduce this value.
// What page to grab!
#define WEBSITE "www.yunuscanyuz.com"
@brief Sets up the HW and the CC3000 module (called automatically
on startup)
String replies;
uint32_t ip;
byte ipp[] = {
192,168,1,8 };
void setup(void)
Serial.println(F("Hello, CC3000!\n"));
Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
/* Initialise the module */
Serial.println(F("\nInitializing..."));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
// Optional SSID scan
// listSSIDResults();
Serial.print(F("\nAttempting to connect to ")); Serial.println(WLAN_SSID);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("Failed!"));
while(1);
Serial.println(F("Connected!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100); // ToDo: Insert a DHCP timeout!
/* Display the IP address DNS, Gateway, etc. */
while (! displayConnectionDetails()) {
ip = 0;
// Try looking up the website's IP address
Serial.print(WEBSITE); Serial.print(F(" -> "));
while (ip == 0) {
if (! cc3000.getHostByName(WEBSITE, &ip)) {
Serial.println(F("Couldn't resolve!"));
cc3000.printIPdotsRev(ip);
// Optional: Do a ping test on the website
Serial.print(F("\n\rPinging ")); cc3000.printIPdotsRev(ip); Serial.print("...");
replies = cc3000.ping(ip, 5);
Serial.print(replies); Serial.println(F(" replies"));
/* Try connecting to the website.
Note: HTTP/1.1 protocol is used to keep the server from closing the connection before all data is read.
Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
Serial.println("Connecting to Client...");
// Make a HTTP request:
www.println("GET http://www.yunuscanyuz.com/ardugelen.aspx?Relay1=Hello");
www.println(" HTTP/1.1");
www.println("Host: yunuscanyuz.com");
www.println("Content-Length: 12");
www.println();
Serial.println(F("-------------------------------------"));
/* Read data until either the connection is closed, or the idle timeout is reached. */
unsigned long lastRead = millis();
while (www.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
while (www.available()) {
char c = www.read();
Serial.print(c);
www.close();
/* You need to make sure to clean up after yourself or the CC3000 can freak out */
/* the next time your try to connect ... */
Serial.println(F("\n\nDisconnecting"));
cc3000.disconnect();
void loop(void)
@brief Begins an SSID scan and prints out all the visible networks
void listSSIDResults(void)
uint32_t index;
uint8_t valid, rssi, sec;
char ssidname[33];
if (!cc3000.startSSIDscan(&index)) {
Serial.println(F("SSID scan failed!"));
return;
Serial.print(F("Networks found: ")); Serial.println(index);
Serial.println(F("================================================"));
while (index) {
index--;
valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
Serial.print(F("SSID Name : ")); Serial.print(ssidname);
Serial.print(F("RSSI : "));
Serial.println(rssi);
Serial.print(F("Security Mode: "));
Serial.println(sec);
cc3000.stopSSIDscan();
@brief Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
return true;
