The thing still comes up with an .localIP being part of the DHCP pool, not what I set under WiFi.config. Earlier posts said I'd need to update my firmware but I believe this is much more up to date hardware so that may not be the problem.
int code, i, x;
char* codeChar;
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
//#include <WiFi.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
IPAddress ip(192, 168, 1, 139);
const char* ssid = "JMR";
const char* password = "c";
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
unsigned int localPort = 8888; // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// start the Ethernet and UDP:
WiFi.mode(WIFI_STA);
WiFi.config(192, 168, 1, 137);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Node7b: Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Udp.begin(localPort);
codeChar = "";
i = 0;
while (Serial.available()) {
codeChar[i] = Serial.read() ;
i++;
// send a reply, to the IP address and port that sent us the packet we received
x = Udp.beginPacket(ip, 8888);
if (x == 1) {
Serial.print("beginPacket status: Success ");
else {
Serial.print("beginPacket status: FAILURE ");
Serial.print("Sent: "); Serial.println(code);
Udp.write(codeChar);
x = Udp.endPacket();
if (x == 1) {
Serial.print("Packet Send status: Success ");
else {
Serial.print("Packet Send status: FAILURE ");
delay(100);
Why should I remove the ethernet.h and ethernetudp.h includes? That would cause the udp to stop working. Should I replace them with WiFi.h (caused more problems.) or wifiudp.h?
mattlogue:
Good. Thing is I'll need to research ESP8266WiFi classes to find out how to send a UDP packet. It doesn't have members named .begin or .beginPacket, etc.
Thank you! A half hour later I get one talking to the other! Right now it's just random numbers to test with, but later it will be codes that actually do things.
all standard Arduino networking libraries for different networking hardware (Ethernet, WiFi, ESP8266WiFi, WiFiEsp, WiFiLink, WiFiNina, WiFi101, UIPEthernet ...) have classes derived from base classes Server, Client and Udp. this classes and some conventions define the standard Arduino networking API
For some reason it, that is the ESP 12E, stops sending "ping" or any packet after a few hundred times OR a few minutes. It still replies to ICMP ECHO requests, however. Here is the new code:
#include <WiFiUdp.h>
const char* password = "c5";
WiFiUDP Udp;
unsigned int localUdpPort = 8888; // local port to listen on
char receivedChars[255]; // buffer for incoming packets
char replyPacket[] = "Hi there! Got the message :-)"; // a reply string to send back
boolean newData;
int numChars = 255;
Serial.printf("Connecting to %s ", ssid);
IPAddress ip(192, 168, 1, 137);
IPAddress gw(192, 168, 1, 254);
IPAddress dns(192, 168, 1, 254);
IPAddress sn(255, 255, 255, 0);
WiFi.config(ip, gw, sn, dns);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println(" connected");
Udp.begin(localUdpPort);
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.localIP().toString().c_str(), localUdpPort);
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData() {
if (newData == true) {
sendUDP();
Serial.print("This just in ... ");
Serial.println(receivedChars);
newData = false;
void sendUDP() {
Udp.beginPacket("192.168.1.139", 8888);
Udp.write(receivedChars);
Udp.endPacket();
void pingOut() {
Udp.write("ping");
Udp.endPacket();
recvWithEndMarker();
showNewData();
sendUDP();
pingOut();
