WIFI configuration
I have a Yun that is not bricked but constantly reboots. The problem is that I was fiddling with the the WIFI configuration and changed the frequency configuration in the advanced setting. As I recall it referred to 3 setting - 20mhz, 40mhz with ... under, and 40mhz with ... over. I changed it from 20mhz to 40mhz ... over setting.
Now my yun is in a boot cycle. WIFI fails to initialize and so it eventually reboots. It does boot - it's currently useless. I can run failsafe over usb - I don't seem to be able to establish ethernet commectivily. I've tried numerous resets - it seems that the various versions (buttons, commands) do not rest the WIFI frequency configuration. Is there a configuration file I can edit to fix this problem - is there a reset that works? I am really stuck here - any help would be greatly appreciated!!
Thanx
