Wifi Connecting but rest of the code is not working
I have a code for Automatic Water Pump controller using esp8266, OLED display and nrf24l01.
Working:
  1. The motor starts when water level is 25% and can be switched to manual and automatic mode
  2. Buzzer beeps when tank is full and it can be turned off
  3. Motor can be controlled through both physical switches and blynk app
I was able to successfully upload the code to board but when i check serial monitor the it says successful Wifi connection along with some un usuall charcters & symbol and it works like loop saying wifi connected again and again.
So please tell whats wrong with this code.
Transmitter Code:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(2, 16); // CE, CSN pins
const byte address[6] = "00001"; // Address for communication
// Define float switch pin connections
const int floatSwitch1Pin = 3;
const int floatSwitch2Pin = 4;
const int floatSwitch3Pin = 5;
const int floatSwitch4Pin = 6;
// Initialize float switch pins as inputs
pinMode(floatSwitch1Pin, INPUT);
pinMode(floatSwitch2Pin, INPUT);
pinMode(floatSwitch3Pin, INPUT);
pinMode(floatSwitch4Pin, INPUT);
// Initialize the radio module
radio.begin();
radio.openWritingPipe(address);
radio.setChannel(76);
radio.setPayloadSize(32);
radio.setPALevel(RF24_PA_LOW); // Set power level to low
// Read the actual states of the float switches
bool floatSwitch1 = digitalRead(floatSwitch1Pin);
bool floatSwitch2 = digitalRead(floatSwitch2Pin);
bool floatSwitch3 = digitalRead(floatSwitch3Pin);
bool floatSwitch4 = digitalRead(floatSwitch4Pin);
// Prepare the data to send
int dataToSend[4] = {(int)floatSwitch1, (int)floatSwitch2, (int)floatSwitch3, (int)floatSwitch4};
// Send data and check if it was successfully sent
if (radio.write(&dataToSend, sizeof(dataToSend))) {
    Serial.println("Data sent successfully!");
    Serial.println("Data sending failed!");
delay(2000); // Send data every 2 seconds
Receiver Code:
#define BLYNK_TEMPLATE_ID "TMPL3byZ4b1QG"
#define BLYNK_TEMPLATE_NAME "Automatic Motor Controller"
#define BLYNK_AUTH_TOKEN "-c20kbugQqouqjlAYmn9mvuvs128MkO7"
// WiFi credentials
char ssid[] = "testcheck";
char pass[] = "123erefnv";
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <AceButton.h>
#include <SPI.h>
#include <RF24.h>
using namespace ace_button;
WiFiClient client;
// Define connections
#define wifiLed 7
#define BuzzerPin 6
#define RelayPin 10
#define ButtonPin1 9 // Mode switch
#define ButtonPin2 8 // Relay control
#define ButtonPin3 11 // Buzzer reset
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_WATER_LEVEL V4 // Virtual pin for water level
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// State variables
bool toggleRelay = false; // Define the toggle state for relay
bool modeFlag = true; // true for AUTO mode, false for MANUAL mode
int waterLevel = 0; // Water level percentage
char auth[] = BLYNK_AUTH_TOKEN;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
pinMode(wifiLed, OUTPUT);
pinMode(RelayPin, OUTPUT);
pinMode(BuzzerPin, OUTPUT);
pinMode(ButtonPin1, INPUT_PULLUP);
pinMode(ButtonPin2, INPUT_PULLUP);
pinMode(ButtonPin3, INPUT_PULLUP);
digitalWrite(wifiLed, HIGH);
digitalWrite(RelayPin, LOW);
digitalWrite(BuzzerPin, LOW);
button1.init(ButtonPin1);
button2.init(ButtonPin2);
button3.init(ButtonPin3);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
display.clearDisplay();
// Setup NRF24L01
radio.begin();
radio.openReadingPipe(1, address);
radio.startListening();
// Initialize Blynk
Blynk.config(auth);
Blynk.run();
button1.check(); // Mode change
button3.check(); // Buzzer reset
// Check for incoming data from NRF24L01
if (radio.available()) {
    int receivedData[4]; // Array to hold float switch states
    radio.read(&receivedData, sizeof(receivedData)); // Read the incoming data
    // Update water level based on received data
    waterLevel = (receivedData[0] * 25); // Assuming floatSwitch1, multiply by 25 for percentage
    if (receivedData[1]) waterLevel += 25; // Level 2
    if (receivedData[2]) waterLevel += 25; // Level 3
    if (receivedData[3]) waterLevel += 25; // Level 4
    Blynk.virtualWrite(VPIN_WATER_LEVEL, waterLevel); // Send water level to Blynk
    // Control the pump based on water level and mode
    if (modeFlag) { // AUTO mode
        if (waterLevel < 25) { // If water level is below 25%
            digitalWrite(RelayPin, HIGH); // Turn on pump
            toggleRelay = true;
            digitalWrite(RelayPin, LOW); // Turn off pump
            if (waterLevel >= 100) { // If tank is full
                digitalWrite(BuzzerPin, HIGH); // Turn on buzzer
// Update OLED display
display.setTextSize(1);
display.setCursor(0, 0);
display.print("Mode: ");
display.print(modeFlag ? "AUTO" : "MANUAL");
display.setCursor(0, 10);
display.print("Water Level: ");
display.print(waterLevel);
display.print("%");
display.setCursor(0, 20);
display.print("Pump: ");
display.print(toggleRelay ? "ON" : "OFF");
display.display();
BLYNK_WRITE(VPIN_BUTTON_1) {
modeFlag = param.asInt(); // Get mode from Blynk
Blynk.virtualWrite(VPIN_BUTTON_1, modeFlag);
BLYNK_WRITE(VPIN_BUTTON_2) {
if (!modeFlag) { // If in manual mode
toggleRelay = param.asInt(); // Get relay state from Blynk
digitalWrite(RelayPin, toggleRelay ? HIGH : LOW);
BLYNK_WRITE(VPIN_BUTTON_3) {
digitalWrite(BuzzerPin, LOW); // Turn off buzzer
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
if (eventType == AceButton::kEventReleased) {
modeFlag = !modeFlag; // Toggle mode
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
toggleRelay = !toggleRelay; // Toggle relay
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
After reading the directions in the "How to get the best out of this forum" post, please edit your post to add code tags.
The problem could be in the wiring and/or pump power supply, so add a wiring diagram and links to the major components.
Hi @immanuel113
welcome to the arduino-forum.
How did your write your code?
Did you add new functions step by step
testing each added function right straight-forward after adding one single function?
or
Did you write it almost at once and then started testing?
Well if you wrote it all at once you many lines of code that can have a bug.
Can have not must have.
The more lines of code the more time it may takes to find the bug / the multiple bugs
Sounds like your ESP8266 resets again and again.
You are working on an informatik project and what is most needed in an informatic project is - guess what ? information
From having posted your code, telling it is an ESP8266, an OLED display an nrf2401 and blynk there are minimum ten-thousands of possible reasons what might be wrong.
Nobody will write 20000 pages tutorial for you to cover all possible reasons
and you don't want to read them.
So speeding up soling your problems by a factor of 1000 times faster is to provide more detail-information.
What detail-information this is
is explained in this tutorial
You should also add the serial output that shows what your ESP8266 is doing.
It is printing important information to the serial monitor
post the serial printing as a so called code-section.
Thanks, I resolved it by debug flags
