WiFi connection is not possible
#include <WiFi.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <BluetoothSerial.h>  // Bluetooth library
BluetoothSerial SerialBT;  // Bluetooth object
String receivedSSID = "";    // SSID received via Bluetooth
String receivedPassword = "";  // Password received via Bluetooth
WebServer server(80);  // Create a web server on port 80
const int led = 2;  // LED pin number
bool wifiConnected = false;    // Wi-Fi connection status
bool bluetoothConnected = false;  // Bluetooth connection status
bool credentialsReceived = false; // Status to check if SSID and password are received
// Enumeration for input states
enum InputState {
  WAITING_FOR_SSID,
  WAITING_FOR_PASSWORD,
  WAITING_FOR_WIFI_CONNECT
InputState currentInputState = WAITING_FOR_SSID;  // Current input state starts with waiting for SSID
// Function to handle root webpage ("/")
void handleRoot() {
  String html = "<html><body>";
  html += "<h1>ESP32 LED Control</h1>";
  html += "<button onclick=\"location.href='/led/on'\">Turn LED ON</button><br>";
  html += "<button onclick=\"location.href='/led/off'\">Turn LED OFF</button><br>";
  html += "</body></html>";
  server.send(200, "text/html", html);  // Send HTML response to the client
// Function to turn the LED on
void handleLedOn() {
  digitalWrite(led, HIGH);  // Turn the LED on
  server.send(200, "text/plain", "LED is ON");  // Send plain text response
// Function to turn the LED off
void handleLedOff() {
  digitalWrite(led, LOW);  // Turn the LED off
  server.send(200, "text/plain", "LED is OFF");  // Send plain text response
// Function to handle 404 errors (not found)
void handleNotFound() {
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i = 0; i < server.args(); i++) {
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);  // Send 404 error as plain text
// Function to connect to Wi-Fi using received SSID and password
void connectWiFi() {
  if (!wifiConnected && credentialsReceived) {
    WiFi.begin(receivedSSID.c_str(), receivedPassword.c_str());  // Start Wi-Fi connection with the received SSID and password
    Serial.print("Connecting to Wi-Fi with SSID: ");
    Serial.println(receivedSSID);
    int timeout = 0;  // Timeout counter
    while (WiFi.status() != WL_CONNECTED && timeout < 20) {  // 20 seconds timeout
      Serial.print(".");
      timeout++;
    if (WiFi.status() == WL_CONNECTED) {
      Serial.println("\nWi-Fi connected!");
      Serial.print("IP address: ");
      Serial.println(WiFi.localIP());  // Print IP address when connected
      wifiConnected = true;
      if (MDNS.begin("esp32")) {
        Serial.println("MDNS responder started");
      server.begin();  // Start web server
      Serial.println("HTTP server started");
      Serial.println("\nWi-Fi connection failed. Please check credentials.");
    Serial.println("Wi-Fi is already connected or credentials not received.");
// Function to disconnect Wi-Fi
void disconnectWiFi() {
  if (wifiConnected) {
    WiFi.disconnect();  // Disconnect Wi-Fi
    Serial.println("Wi-Fi disconnected.");
// Function to start Bluetooth connection
void connectBluetooth() {
  if (!bluetoothConnected) {
    SerialBT.begin("ESP32");  // Set Bluetooth device name
    Serial.println("Bluetooth started. Device name: ESP32");
    bluetoothConnected = true;
    // Prompt for SSID input
    SerialBT.println("Please enter SSID:");
    currentInputState = WAITING_FOR_SSID;  // Set state to wait for SSID
    Serial.println("Bluetooth is already connected.");
// Function to disconnect Bluetooth
void disconnectBluetooth() {
  if (bluetoothConnected) {
    SerialBT.end();  // End Bluetooth connection
    Serial.println("Bluetooth disconnected.");
// Function to disconnect all connections (Wi-Fi and Bluetooth)
void disconnectAll() {
  disconnectWiFi();
  disconnectBluetooth();
  Serial.println("All connections are off.");
// Function to handle incoming Bluetooth data
void handleBluetoothInput() {
  String incomingData = "";
  while (SerialBT.available()) {
    char receivedChar = SerialBT.read();
    if (receivedChar == '\n') {  // Stop reading when newline character is received
    incomingData += receivedChar;  // Append received characters to the incoming data string
  // Process SSID or password input based on current state
  if (currentInputState == WAITING_FOR_SSID) {
    receivedSSID = incomingData;  // Store received SSID
    Serial.println("SSID received: " + receivedSSID);
    SerialBT.println("SSID received. Please enter Password:");  // Prompt for password
    currentInputState = WAITING_FOR_PASSWORD;  // Set state to wait for password
  } else if (currentInputState == WAITING_FOR_PASSWORD) {
    receivedPassword = incomingData;  // Store received password
    Serial.println("Password received: " + receivedPassword);
    credentialsReceived = true;
    // SSID and password are both received, wait for Wi-Fi connect command
    SerialBT.println("Credentials received. Press 'w' to connect to Wi-Fi.");
    currentInputState = WAITING_FOR_WIFI_CONNECT;  // Set state to wait for Wi-Fi connect
// Function to initialize the system
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);  // Set LED to off by default
  Serial.println("ESP32 is ready. Waiting for Bluetooth input...");
  // Start with all connections disabled
  disconnectAll();
  // Set up web server routes
  server.on("/", handleRoot);
  server.on("/led/on", handleLedOn);  // Route for turning LED on
  server.on("/led/off", handleLedOff);  // Route for turning LED off
  server.onNotFound(handleNotFound);  // Handle 404 errors
  // Start Bluetooth connection
  connectBluetooth();
// Main loop function
  // Handle web server client requests (only if Wi-Fi is connected)
    server.handleClient();
  // Handle Bluetooth input
  if (SerialBT.available()) {
    handleBluetoothInput();
  // Handle keyboard commands from the serial monitor
  if (Serial.available()) {
    char command = Serial.read();
    switch (command) {
      case 'b':  // Connect Bluetooth
        disconnectWiFi();
        connectBluetooth();
      case 'w':  // Connect to Wi-Fi (after receiving credentials)
        if (credentialsReceived) {
          connectWiFi();
          Serial.println("No Wi-Fi credentials received. Cannot connect.");
      case 'f':  // Disconnect all connections
        disconnectAll();
      default:
        Serial.println("Invalid command. Use 'b' for Bluetooth, 'w' for Wi-Fi, 'f' to turn off all.");
Since I have an esp wroom 32 module, wifi and bluetooth do not work at the same time, so I created this code. However, when I try to connect with wifi ssid and pass, it still doesn't work. Please fix it!
To work with bluetooth and wifi both together, you can check these out.
I moved your topic to a more appropriate forum category @arduinosohot.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
